Tim Humphreys ex Mudhen
Richard/Mick
On my JLTRT class 40 I used Slaters wheels which I turned to pretty well near scale thickness and then found, as you mention, that the bosses need a lot removing from them; I took-off about 0.5mm. The big difficulty then was the thickness of the sideframes, this took a lot of work with a coarse file to provide clearance and caused concern about damaging the sideframes in the process. It was eventually successful and now I'm trying to ensure the pony truck works consistently, I've used wire springs attached to the outside of the frames resting on top of the pony truck bearings; getting the correct amount of downward pressure is the big issue.
Richard, after working on the Slaters wheels I had exactly the same idea as you; why not turn them from mild steel bar. I've produced LNER tender wheels this way and can't imagine why I didn't think to do the same for the 40.
Here a couple of poor pictures of the spring arrangement
