Ok, just a small update, got my wheels back from Colin all S7'd and the axles from JP so time to get on with the chassis, so puzzle number one was which axle to drive and finally decided on the middle one, simply because I've no confidence that I can get the split knuckle rods to drive effectively through the split and all work nicely, which effectively makes my 0-6-0 an 0-4-(0-0)-4-0, therefore no compound errors in my sloppy rods or horn guides to contemplate.
The early choice of driven axle was good as the next stage of getting said wheels onto said axles means that once on, there not coming off! I understand the taper should be tight, but I had to hammer the axles home with some force to get them all the way on, turns out the 10thou taken off the back face may well have had a small contributing factor in reducing the effective taper size on the wheel? None the less five were driven home and are effectively sealed for life, a puller might get them off but it'd have to tuck right into the boss as if not it'll surely break the plastic spokes.
For the last, as it's going to be on and off a bit, I decided to sacrifice some tightness and just ran a file over the axle taper, instead of the 1mm gap at hand tightness (last 1mm driven home under force), I've about 0.25 and even hand pushed home there's still about a 0.05-0.1mm gap for the last big push, said modified taper is clearly marked LOL.
So onward, gearboxes, just as a trial I ran with the Roxey 13:1 coupled to a Mashima 1833 that came in one of my recent kit purchases, whilst it ran there were a miriade of issues, it's almost impossible to fold up square
, I have another to try later, but it ran and said vehicle moved across said work bench, even though driven by one centre axle in a satisfying manner. Second issue was side float on the gear wheel, depending on direction of travel, said gear wheel like to impart a side force and move the axle correspondingly, not a problem if theres room for the motor gearbox combo to follow, in my case the hole for motor gearbox combo doesn't, thus on impacting the side of the chassis then imparts a twist and lifts the axle correspondingly....not impressed.
So with all those issues I decide to junk the Roxey gearbox and recover ball bearings for use in the new super dooper S Dale gearbox, first off it folds up perfectly, I decided to construct it in idiot style, no cleaning, no scoring, no care, just fold up, open bearing holes for ball races, insert shaft and motor and run, worked perfect right out off the bat, very impressive.
Having confirmed it was a million times better than the previous experience I went back and soldered up and fettled clean, again side play is an issue so some washers in there are a must.....or a new idea I have, getting exact spaced washers to fit in there might be a problem, so I have come up with a simpler (I think) solution which requires rubber tubing cut to length, this will ensure the gear wheel stays exactly centred on the worm and will push against the inner race of the ball bearings so should be a perfect fit as rubber tube is easier to cut to size and if overly long by a few thou can and will be compressed to take up the slack (photos later on this evening once in practice).
One thing I did find was that Stephs is a much shorter box than Roxey and the Roxey worm is too long as it has a grub screw retainer, so part of the front of the gear box was removed to accomodate the worm, which still didn't work as the end of the worm near the grub screw does not clear the teeth on the gear, I have a solution for that (the correct way would have been to get the correct gears from Steph! but I was in full bodging mode yesterday LOL) and will trim off the grub screw end of the worm and affix worm accordingly. I only mention that as someone will look at forecoming photos and wonder what an earth I have done LOL.
The next problem is of course the ratio, it's stupid high for an 08, even at 4v it whizzes along the desk at a silly high speed, so whilst this gear box will not remain it is proving several issues before the main one goes in and allowing experiance to be gained before the 'right' one is installed.
Which begs the question, which gearbox do I ultimately use, of course the ABC two stage would be perfect, but at a cost and do you really need that quality, most will answer yes, but honestly, do you? Are there alternatives, I'm looking at the Roxey two stage 40:1 and working on the premis that my previous bad experience is down to my ineptitude. What I'd like to do is perhaps work up an etch for a slow speed gear box and try as I might I cannot find the same worms that ABC seem to use, they look to be more pitched than those readily available, I'm using a twin start worm but ABC seem to use a four or even five start worm, which is clearly how they get them so free running and allow the loco to run on.
I've also seen many fine models move at crawling speed, quite critical for the 08 to be fair, they can't all be using ABCs can they? So there must be other alternatives around, all of which falls into what Steve O is looking into and from previous discussions here and elsewhere.
For the record, current tests were done under DC, a 40yr old H&M truth be told LOL, so I accept DCC might give a mildly better slow speed control
