Adrian,
In reverse order, I'm an N-S devotee and I think I said whilst doing the class 40 bogies I'd never go back to brass, however, when one has 'several' yards of brass buck shee it's as good a material as any to learn on, when I get better I'll certainly go over to buying N-S sheets and working with that, certainly any etch work I do in the future will be N-S.
Filing, well I just file until it looks right, the paper most certainly does not move with this tape, nor loose its shape...that I can ascertain. In fact I used it to stick two 10 thou templates together for the o8 bonnet, they didn't come apart without distorting the two parts, this stuff'll stick aircraft wings on and its pretty thin too so when filling the paper just tends to scuff ever so slightly at the edge.
However! I do take your point about accuracy and it is something to consider. When I did the art work for the class 40 bogie the snap scale was 0.05mm, the art work for this project is 0.25mm, how accurate do you really need to be? I don't know and going from uber accuracy to yard broom accuracy is basically a trial into seeing what can or cannot be accomplished.
Scribing is much more accurate and yes it does give you a nice line to file up to, but can one be sure the scribed line is accurate, even under a glass I have trouble discerning 0.25mm on a rule, to scribe to say 0.1mm would be very difficult, yet you can easily etch to that level, again, how accurate do you 'really' need to be?
If the part was a simple shape then yes I'd probably would have scribed it, the wrapper and boiler and probably firebox will be scribed, not necessarily for accuracy but speed, its easier to scribe them than it is to work them up in CAD, print off and stick down.
The primary reason for printing was laying out the rivets for pressing, there's a good 50+ on the cab sheets alone, scribing all of them would send one mad LOL
Regarding accuracy, there is off course the ultimate get out of jail card, take my reading glasses off, then everything looks excellent
The resultant cab sheet part which is first up will be the true acid test of the above techniques, if it all goes together and solders up with minimal dressing then I'll be happy, if it doesn't then it'll go in the bin and I'll try another way
All sounds a bit amateurish and garden shed sort of thing, but sometimes I think we can perhaps go just a little too far in the search for perfection (40 bogie to 0.05mm) when in reality we'd be better off making representations that look good in an overall context. Not saying engineering perfection is wrong, just that there may be other ways to achieve inner piece LOL
