When he has a glass to his mouth.....He lets you get a word in?
Better week this week (well the last three days) and onto a new project, Gladiator ROD (BRE 04).
An old kit going by the box but nothing to untoward so far other than the rave angles, they're not fitted as yet as they need battering into shape to fit, neither is the fall plate as I need to make sure there's not one on the engine and they conflict.
There's an awful lot of white metal in the box, most can be used but I opted to not fight the axle boxes and springs for two reasons, I already had the correct GCR axle box and spring drawn up for a previous customer and second, the kit axle box covers were not the right type for this particular engine.
In all fairness the axle box castings are rather nice so I've kept them for possible use in the future with a 3D spring and hangers. Sadly the springs and snubbers in this kit went straight in the bin.
The kit builds tenders with a tombstone (on it's back) type combined filler and scoop dome, but I needed a later non scoop set up with modified division plate (basically an arched top edge...and I do still need to add a beaded strip across the top of the rear edge).
The rear division plate also needs to be moved back several feet, which increased the coal capacity slightly; the new tank filler is nothing more complicated than a turned down length of tube with a lid on top. The coal space is pending feedback from the client as to how much coal he wants.
63601, BR 04 in 1957.Mickoo Malta GC looks amazing.
Can I ask which ROD you are doing? The usual arrangement with the ROD tenders is a straight topped rear coalplate/division plate with two stanchions to the rear.
ROD tenders also tend to conform to the earlier 'standard' (no such thing with GC tenders!) in having shorter coalguards at the side rather than the longer type fitted to GC locos from the B8 and O5 onwards. If you've got Part 2 of Geoff Holt's Locomotive Modelling books then that has a GA of the B4 tender showing the shorter coalguards.
Here's a J11 with the shorter coalguards (albeit my tender is still wrong in that the front curve of the tender flare isn't elongated as it should be on these tenders):
As built the middle axlebox on these tenders also had longer springs than the outer two. A complete minefield!
Regards,
Cab side sheets not cab front???I took 1 mm off the cab front and rear edges (not the roof overhang extension)
Correct, bad grammar. I took 1.0 mm off the front and rear edges of the cab side sheet.Cab side sheets not cab front???
Interesting that two top notch builders discover the same issue, so we know it's real. Why don't builders give feedback to suppliers? We cannot improve unless we get constructive feedback like this.
David
Regarding feedback, I've heard feedback was and has been given over the years and has (to be polite) been bluntly ignored.Cab side sheets not cab front???
David
To be fair, when you're building commercially there is an expectation to get things right and from that context you look harder at the base kit and find more issues, more so than I suspect a casual builder would, or dare I say it, worry about.David,
looking back over my own 7mm journey, I suspect the answer to your “why don’t” question is one of confidence. The chances are that the vast majority of kit builders have only built one or two, at most a bare handful of locos, and they assume if something is just not quite right, it’s “their fault”.
Unless the issue is glaringly obvious (like two left hand sets of valve gear etches) the builder is less likely to conclude the kit design is incorrect, particularly if they can measure something simple like a cab side and conclude it’s correct.
Coupled with the likely, and fundamental, truth that few of us at the back of the class have Mick’s (and Tony’s, and a few more on here) encyclopaedic knowledge of the prototype.
just my 2c.
There's also an ambiance within the community that some fettling is good character building and part of the journey in making kits, being relatively new to the scene I find that approach utter bollox.
Sadly I think that is the norm rather than a one off I'm afraid, usually you get the "no one else has complained" response trotted out, to which the answer is "perhaps no one else was looking or cares", but it's still wrong. The fact that you had to justify the error is a good indication nothing will happen, if they're not man enough to take your initial approach and check themselves then it's usually a lost cause.I had a bad experience when pointing out a significant error in a 4 mm kit to the manufacturer. The loco was almost complete when I stood it alongside an existing model of a related, similar loco and realised that the cab roof was far higher on the new kit. I wrote to the supplier who replied, in fairly strong terms that he was a member of a master craftsman's guild and couldn't possibly have made such an error and, basically, that I was lying. to prove the error I did a table of comparisons between prototype dimensions, scale equivalent, measurements from a published scale drawing (a copy of which was included with the kit!) and my model covering height to footplate, top of side tank, top of cab side and to crown of the roof profile. The footplate height was within a quarter of a millimetre, the top of the cab side was slightly high but the roof was a full two millimetres too high. I had no further reply from the manufacturer.
I managed to file about 1.5 mm off the spectacle plates which reduced the height to give an acceptable appearance but altered the roof profile to something really not right but the best I could do with a fully built loco.
So, overall, a not very satisfactory experience of contacting a kit supplier. hopefully, this was an exception and I'm sure David's response would be much more positive.
Dave.
Peter and I have five GCR tenders from DA so maybe we can knock on your door when you have done replacements as etches.I have another GC ROD tender to do next year, this time from DA so it'll be interesting to see how close they are, I suspect very close, in which case I'll get new flare strips etched up and if they work will gladly pass on to David if he want's to add them to his stock.
No problemsPeter and I have five GCR tenders from DA so maybe we can knock on your door when you have done replacements as etches.
I've checked some photos and you're right, the rear division plate is flatso I checked the reference photos taken on a visit to GCR and it's also flat, so I have no idea why I made a new curved one
It will be flat very shortly!
