A little more progress on the LNWR 2-4-2T (finally), I have a very bad habit on not forcing solutions and the front end was a little niggle to overcome.
The smokebox front drops down between the frames, nothing unusual there, but on the 2-4-2T there's no footplate so essentially it needed to be a part of the footplate, not quite sure where the fireman stood to empty the ash mind and as far as I know they retained this feature until scrapping.
The obvious choice was 3D but I wasn't quite there with settings, supports and design to get something that fitted, warp free and as artifact free as possible.
The first model is a form and fit venture with crude settings, much better to bin a 7 hr print than the production 13 hr print. The primary aim is to make sure it all fits, supports work and orientation doesn't generate warping or pressure waves. A quick sloppy coat of primer helps highlight any potential errors.
The little wrapper flares over the footplate are currently 0.6 mm thick but once the sacrificial edge goes should be down to 0.3 mm, I can live with that. There's also a little gap between the front and frames and the next (final hopefully) rendition resolves that.
The module is bolted to the footplate with two 10BA screws, massive overkill but it can't be allowed to move or the fixing fail, to make life easier two hexagonal recesses hold the nuts and they will be glued in on the final version; the central screw holds the footplate to the chassis.
The chimney is thin walled 3D and is supported internally with thin brass tube for strength, anchored inside the smokebox with a big profiled block and running to just below the top.
Ideally you want the smokebox door as part of the main module but then that limits you securing the boiler with the central screw and fitting the captive nuts, always a ying and a yang designing modules like this. The final rendition will also have the push pull gear features as bolt on parts.
Now this in place the rest can work around this, internal cylinder block (3D) and boiler (brass), once the cylinder block is in place then the slide bars and motion bracket can go in and then we're back on the yellow brick road joining the rest of the dots up.
