Awsome, I love those shovel nosed electrics, a derivative is also used in Holland, and yes, they are on my list of models I want to add to my collection
I have the info and some drawings to be getting on with, just not the time.
I was fortunate to see one of the bigger CC multivoltage class in Belgium, the French ones were a fancy silver with red trim and the noise was impressive as it screamed past, later I got haulage by one of the Belgium ones in Silver with yellow and blue trim on a rail tour from Oostend to Brussels where we picked up out planned haulage by a Nohab on which I managed to blag a cab ride
That is one Euro can I keep a very tight lid on, Nohabs and Belgium EMD 567 locos....which reminds me, I really must start to scan my 35mm collection.
The TGV's are nice as well, I like their styling and the Duplex and Thalys are also very dashing, oddly I don't think the Eurostar has quite the same impact, though all three are from the same design board and stable, Eurostar is just a quart in a pint pot TGV.
Anyway, here in glorious technicolour is a 'real' engine,
and yes I am trespassing....but only a little bit
, but it was very early on a Sunday morning and a quite totally isolated yard
In fact I wandered around the whole depot at Aarhus
and saw only one person who said good morning and walked right past me.
I had the fortunate pleasure of travelling on one of these IC3 a few days later after a monumental cock up in my travel arrangements! Like being late for my flight by 12hrs, followed by a mad overnight rush to the other side of the country to pick up a morning flight back to the UK.
These are impressive units, very quite, very smooth and bleedin fast, they're diesel mechanical with a seven speed gearbox and auto engine management, gears 1 to 4 step up real quick to around 40mph then in gear five they really let go, the engine digs in the note changes to a deep growl and you can really feel the turbos kick in and they accelerate really fast, gear six comes in around 70mph and still pulling and gear seven is around 90mph which is more like an overdrive and takes it up to the top speed of just over 110mph.
The only way you know it's changing gear is the engine noise, there is no lull in the pull or acceleration, I understand that the engines do not all change gear at the same time, there are four engines to a three car set so by staggering the change over by a few seconds you get an almost smooth acceleration curve.
Everything on these units is modular for a quick change over, here's a fuel tank and engine ready for servicing I suspect, given the dirty state of them
Here's one of the bogies, the engine and transmission are one rotation only, obviously engines cannot run backwards but the gearbox is a one way set up and reverse is done at the final drive on the bogie
The white bags are there to protect the primary suspension springs, the grey disc is where the drive shaft attaches and the lever arrangement on the rear of the gearbox is the reversing mechanism. Braking is done by those vented discs on the axle, no tread brakes here.
There are two types of bogie, this one has four 'small' white bags which means it is a mid train bogie and supports two coaches, behind is a bogie with two 'large' red bags this is an end of train bogie, basically it's three coaches on four bogies and four engines on the outer coaches, the middle coach has no power plants.
Yes, I also have enough photos and info to make one of these as well, plus I'm planning a Euro trip next year in Germany but might pop North and grab what ever shots I need for existing projects....I didn't take nearly enough detailed TRAXX images last time.
Padborg is the change over from Danish 25Kv to German 15KV, although there are wires the full length of the change over sidings there is no power, when the loco enters from either end they drop their pantographs and coast through the siding, when they stop they then raise the correct pantograph for the new country and supply. This loco will remain on this train for the whole journey which started in Sweden and will end up probably in the German heartland. Though it could of started in Norway which would use the German 15KV pantograph.
This TRAXX version only has two pantographs so is limited to 25Kv or 15KV both AC, other sub classes can have four pantographs and cover DC as well, I think there are only a hand full that can cover all of Europe but most are for specific operators on specific routes. One interesting thing is that even though Switzerland is 15Kv like Germany their pantographs have a much smaller head due to curvature and tunnels. Swiss locos can work into Germany but have to be careful that the wire does not have too much lateral swing as it'll drop off the head, so they are limited to certain routes that have been modified and cleared for native Swiss locos, plus adding in the required cab signalling.
Conversely locos fitted with a DC pantograph may not be truly universal, Belgium runs on 3000V DC, as does Italy and Spain, but Holland and southern France still run on 1500v DC so the universal DC locos only run at half power in Holland and France. There are now though (I think, kinda lost track on TRAXX production these last few years) some dedicated DC/DC/AC/AC engines that can accommodate the two DC systems and two AC systems.
The best thing about Hectorrail is that they name all of their locos, this series are all named after Starwars characters, in this case #5 is Solo but the best #10 Yoda
yes I did get to bag some photos of that one.
Another TRAXX, this time a German owned one ripping through Middlefart in Denmark, the MZ in the train is under power and will probably be used for the final leg which will not be electrified or it could be balancing power, mind I do recall that this was a particularly long heavy train so it may have been there for the extra power.
Yes I do have more than enough info and details for a TRAXX loco, even got around to doing some 3D work for the cabs for each generation. Just never got around to printing them, nor the 110/140 cabs I did as well
The basic idea behind the TRAXX cabs is 3D printed but with a side overlay from the body to hold it in place and a thin etch front as well, that's why there's a small recess between the corners and the large flat pieces.
Book you say, been there, done that,
Anglia Rails A personal view by Michael Davies: Travel | Blurb Books a rather boring affair really LOL, only sold one copy but had three printed for myself, it's nice to have something printed on your shelf though
The problem is the pricing, they want so much before you even see a profit, I think my Profit margin is £1.25 per book so you can see how much they get.
It is a good service if you want books for a special occasion, my mate does it for wedding photos, much easier and cheaper to send wedding photo books out to guests and family than trying to get orders in from who and what each one wants, no one ever looks at wedding photos but a book seems much easier to pick up.
