Mike Garwood
Just back from Barrow Road, I'll edit this post in due course to give a fuller report. But, in the mean time...
Stay safe
Mike.
Stay safe
Mike.
Forever the pessimistQuick update on the 63xx...
Chassis is completed other than some nuts that need soldering in. I'm not going to add the cosmetic sides. I had my fingers burned on the 51xx with that and I'm not going thru that drama again.
Also completed : cylinders, G hangers, front bogie and all the brakes, and I started the cross heads (which are a great design). Other jobs completed - but cannot be seen - Identified all the parts from the etches that will make up this engine. I did widen the cylinders by 1.3 mm. It's best to pay attention to what other gifted modelers have done on their build.
I have a complete set of Keen Maygib wheels for this kit. The tender wheels are right out of the ark...they have one-eighth axles that you have to cut to length yourself. I haven't had to do that since I built a DJH Hall with Sharman wheels (remember them?). That was 1998!!
Absolutely no problems in the build so far, but I'm sure that'll change!
Stay safe
Mike.
I have some sympathy with this point of view, Mike, especially if the absence of the overlays isn't that obvious when the loco is complete, painted, weathered and in operation on the layout. Far more important in my view is a loco that runs well and looks good in overall terms.Chassis is completed other than some nuts that need soldering in. I'm not going to add the cosmetic sides. I had my fingers burned on the 51xx with that and I'm not going thru that drama again.
Hi Simontop marks for the use of a vernier as a g-cramp….
Probably better that than as a scriber .top marks for the use of a vernier as a g-cramp….
But doesn't the plastic wear out ?Guilty, m’lud.
(on the basis that they’re now about a tenner, so pretty much in the “consumable” category)
Not looking too shabby. Having now studied the castings in detail, I do not appear to have the bell shaped casting that sits in the middle of the lower / front footplate. Cannot remember the name of it for the life of me! Has anyone any idea where one of this part can be obtained? I've checked my usual suppliers (looking at photos, until the name drops into my empty head) without success. I may end up scratching this using...who knows what.
