Rob Pulham
Hi Rob,
Thanks for your positive comments.
Chris's wet palette sounds very similar to mine, except instead of a grid under the parchment paper, I'm using several layers of plain white kitchen towel to hold the water.
Do you know if Chris has found a source of 'bleached' baking parchment paper Rob, as the only stuff I can find down the supermarket is the 'unbleached' kind. I know it works the same, but being brown in colour, it doesn't make as good a palette as the white stuff sold by the local art shop i.e. I find it better to mix colours on a plain white ground, but, the art shop stuff is a bit pricey!!
Hi Mike,
Sorry I don't know anywhere that sells it - Chris uses the brown stuff.
What you need is someone that works in the food industry - preferably in baking. back when I was in the trade we used sheets of silicone paper and a quick browse of the Amazon brings up some in smaller quantities
For cooking pies/breadcakes etc. you can use it many times and it's much tougher stuff than that which Chris uses.
