Apart from starting to fill the screw holes of the outside frames prior to painting (red and yellow to signify Hornby), I’ve taken a hiatus.
The weather for one thing stops play as I need to undertake some of the work outdoors, and for another, I need to psych myself up to a spot of decorating elsewhere to ensure the maintenance of domestic harmony.
Consequently in some downtime, I’m exploring ideas about how the station will develop and the methods adopted to ensure that it’s wholly removable for access in the event of track maintenance for instance.
Exploring other avenues (there always seem so much to be considered in the hobby), I need to take stock of the number of locos which will need to be chipped (never attempted this before) and where to start, as I’m going DCC,if only to ensure that I avoid the dreaded stall on plastic crossings.
Some of the locomotive stock will be the old fashioned tender drive type, the sort that won’t matter when they inevitably crash to the floor, and for which there are one or two handy videos about showing how to ‘chip’ the Ringfield (or even replace it!).
Fortuitously, going through photos of other locos stashed away, I’ve discovered that several are already DCC ‘Ready’, which is a relief.
Funnily enough, having bought the odd one or two over the years, I’d started to forget what was contained in my eclectic fleet, and the following is such an example: a Hornby Hall (okay, not strictly Eastern or Southern as the layout is London based, but as it’s a mere trainset, anything goes……..).
This was a bargain purchase from Hattons at the time which, according to the dates on the photos in the album, was at least ten years ago (circa £50 new). Also, not only is it DCC Ready, but it has a flywheel which excites me and which I’d also forgotten all about.
Now, I suspect one of the reasons for its ‘bargain’ price was to do with the fact it was red! Thus (for my topical proposed BR Western layout) it had to be repainted.
Influenced by several photos of suitably beaten up examples kindly forwarded to me by
@oldravendale at the time, I set about trying to replicate the worn condition of those in the photos. It occurred to me that whilst I admired the offerings of some of the offerings of retailers providing a weathering service to proprietary models such as this, they didn’t quite recreate that dull, metallic sheen(?) of those - albeit extreme - examples in Brian’s collection.
So, with nothing to lose I suppose, and buoyed in the knowledge that in the event of it all going t1ts-up, I could just start again, I started to make it up as I went along using whatever ancient Humbrol enamel greens were in my paint tin at the time, although I recall buying a new one (Brunswick Green ?) for the purpose which appeared to be similar to a BR green in pictures, which I wasn’t so sure about when I opened it!
Anyway, choosing an extreme victim with a burnt smoke box from the available photos, I went ahead - after priming both loco and tender - with washes and dry brushes, and the odd stipple or two, of the available selection of greens, mixing them together as I sought fit, and occasionally adding a dash of yellow on a mere whim to each mix. The same method was used for the colours chosen for the smoke box, including a basic rust colour which was to be developed further and enhanced, prior to and after, creating a dirty black and peeled surface to represent scorching.
Only I never got that far - as usual.
Anyway, enough waffle, and as a change from boring wood, here’s where I got up to in 2015:
The example in Brian’s photo had missing nameplates, so I attempted to replicate this. Unfortunately, on removing the Hornby plates I recall there being no mudguards, so some were fashioned from strips of brass suitably cut n shaped n drilled, with the finest pieces of wire in my possession soldered in to represent the brackets. They look like they still require a spot or two of filler.
The tender:
Yep, the transfers…….
As the finish thus far was ‘flat’, I realised it wouldn’t be suitable for the reliable application of transfers, so an approximation of the outline was carefully painted on in gloss varnish and allowed to dry prior to applying with water and finishing with a product purchased from the States………only, with all the water and product applied, I lost sight of the gloss outline beneath…….and fixed em in the wrong place……
As a footnote, on looking again at the long forgotten pictures of the model, I realised it must have been perhaps a railroad edition, as I appear to have fashioned my own brake gear from brass wire, soldered into something vaguely resembling the real thing:
I think this might just be one of my first victims for chipping when the time comes.
Anyway, I hope nobody minds my slight and rather random deviation from the spine of the thread.
Until I eventually get round to the build once again, Happy New Year!
