Yet another busy family weekend, but I managed to squeeze in a little more modelling:
You’ll be relieved to know that this wont be a blow by blow affair, but I wanted to progress this initial part of the build, if only to demonstrate that the use of another type of adhesive - and the biggest threat to laser cut material IMHO - Pva, hasn’t been as detrimental as expected.
It’s been used to fix the decorative stone quoins(?) and parterres around the arched openings, formed of dual thickness watercolour paper. I suppose it’s not a fair test as things go, as the parts here are well supported, over and above - I suppose- that which would form part of normal construction methods, but it goes to show that as long as these kits are built with this in mind, they shouldn’t prove any more of a minefield than say a cheap styrene based kit, and prove robust models to boot.
Finally, you’ll see what I mean when I write that this is built in the spirit in which it was intended: a child’s train set, and therefore in comparison to the earlier photos of the prototype, it hardly bares a nod to the real Blackfriars. However, in doing so, I’m honouring a promise to a good friend by not getting caught up in the detail, and assist in helping me keep within a realistic timescale of completion.
Next I’ll add some token quoins to the vertical columns, before adding the arched frames for the doors and window lights. Then it’s on to working on the first storey which will be a mask for the station roof handle, and which will also be removable like the station roof itself.
Thanks all for your kind words, advice and likes to date.
