Hope that helps (probbaly not as they are from the latter built batch)
can either of you advise which vehicles had the offset roof lights.
Graham
Sure does, looks like we have Slater's bearings for Peartree axles.Not sure if this helps but these are the 2.5mm O/D plain bearings Peartree supply to fit their domed/straight journals:
Earlier this week I spoke to Dick Taylor about which vehicles had offset lights / central lights as he showed me some prototype information when we bought the kit at Telford. As of now, his understanding is that vehicles 96286-96288 had offset lights... nothing is known about 96289 or 96290... and the remainder seem to have had central lights. What is not known is if the change took place during building or later in life.Who knows about the condemnation dates for these vehicles? Specifically, I wish to select a number for an example with the offset roof lights and extant in the late 1980s.
a class 37/4 which was "built" in the late 1980s.
Yes.In this case you refer to the 37/4 being "built" in the late 1980s. Is this a rebuild of an existing class 37?
Jenks, RIP....who is going to question the Authority of rule 1?
of interest to us are the engines which gained Electric Train Heat alongside of a change from generator to alternator, these engines became a new sub-class of "37/4" with numbers like 37401... Other re-build variations at that time gave us sub-classes 37/3... 37/5... 37/9... .Graham
Work on fitting the castings to the ends has raised a question. or three.
There are no castings for vacuum or steam heat bags - what products are recommended by WTers?
I have seen a photo on @paul bartlett 's wagon website which shows that these vehicles had acquired ETH cables and air brakes by mid 1980s.
What products are recommended by WTers for those items?
For the air brakes the above photo shows only the yellow coupling (main air pipe?)...where these vehicles fitted with a reservoir pipe?
Thank you, Peter
