Dare I suggest a tender caress with a "Tack-Rag"? Much used in the automobile-spray business... a fine weave scrim which is tacky. Does what it says on the packet etc..My problem? I used a fibre mop to polish the sides. I forgot to make sure the sides had been cleaned of all strands before spraying commenced.
Dare I suggest a tender caress wiht a "Tack-Rag"? Much used in the auto-spray business... a fine weave scrim which is tacky. Does what it says on the packet etc..
If you have difficulty in finding some I might be able to forward a couple from here - each rag comes in its own plakki-wrapper so will not get stuck in the post!You may certainly suggest it. I shall source some for the next project. Thank you.
Surprising to read this for the Halfords' range of primers in rattle cans are much used in the 7mm modelling world. If the spray pattern is to "big / broad" then try a different "top" to the can. The rattle cans from Games Workshop generally have a "smaller / finer" spray pattern than the Halfords' cans (also more like a cone than the broad swipe from some rattles).I think part of my problem is the rattlecans are designed for automotive repair. The spray pattern is wide for coverage, but perhaps a little too wide for the scale I'm working with.
I am not sure that this had been mentioned in earlier posts... apologies if I have missed the details - these Mk.2 carriages are to be vac braked? air braked? dual braked? Steam heat? ETH? dual heat?
BTW I did my MK2's the opposite way round (blue first) as I found it easier to mask![]()
No coverage problems with grey over blue for me Heather when I did the MK2's with RailmatchThere is something in that, but it's the covering ability of the paint I worry about. The last four coaches I have built for Richard were airbrushed using Precision enamels, and getting any coverage over the blue with the grey was impossible. Therefore, I take the view I start with the light colour, and overspray with the dark colour.
Hi Heather,
I also had no problem with grey over blue on the 12 JLTRT Mk1s i built for iploffy. (Area 51, MTH workbench)
I also use Railmatch.
Was that rattlecan paint, or mixed from tinlets with thinners? I think that's the difference.![]()
dare I ask what your 'patent grot mix' is?
On the Blue/Grey front, I have just checked the HMRS pre-drawn ends for the white lining and as close as I can make it out, centre to centre is 27.5mm which is 3'11.04" and between the inside faces it's 26.5mm or 3'9.36" so there is no mileage to be gained by going along that route.
It's quite simple. It's a 50:50 mix of matt black and matt earth (Humbrol 33 and 26 or 29). It gives a head start on weathering underframes.
In other news, still nothing from Scotland. I'm in danger of grinding to a standstill for want of brake components on the two remaining kits.![]()
