JimG
Paul,
If you are CNC milling the nuts, then peck drill the holes using CNC with a slot drill of the appropriate size, or profile mill the holes with a smaller diameter slot drill. Then you avoid the problems of locating a drill in a subsequent operation.
Jim.
To turn to cosmetic nuts, which could be either square or hexagonal, I think the bet approach is by CNC milling or engraving of styrene or other plastic such as ABS or acrylic.
Below is a photo of 1/32nd scale 7/8" whitworth bolts in styrene.
The size is roughly 1.5" by 2.5", and the spacing is determined by the diameter of the parallel engraving cutter used. In the case of the above sample the central hole dot was made with an engraving cutter, and this has resulted in the .55 mm drill used to cut oversize, or as can be seen to jump out of the dot. Future production will use a centre drill to mark the hole position which should avoid oversized or misplaced holes.
Jim.
