Further to the above entry, this cottage in Parkend is, I believe, known these days as 'The Nook'. Certainly this is the name given to it by John Stretton in 'The Dean Forest Railway, a Past & Present Companion', Volume 2 (Silver Link Publishing).
This cottage, plus the house to it's left (the former Police House and Police Station for Parkend and currently known as 'Hazledene') are very close to the end of the Marsh branch at Parkend, which is the subject of Re6/6's current P4 project outlined in this thread.
However, for the purposes of this thread, I will be referring to it as 'The Other House'.
Both cottages are required for John's layout, although the Police House will need to be cut down slightly, to fit with the backscene and the rear edge of the layout.
I agreed to build both cottages for John and am hoping to get them finished in time for the 'mini-Scaleforum local show for local people' type event that is taking place at our Area Group's (aka 'D.R.A.G.') normal venue near Teignmouth on the Saturday of what would have been the Scaleforum weekend (25th September coming).
There aren't a whole lot of published photos of either cottage, although the Police House does admittedly feature in rather more photos than 'The Other House'.
We know that the Police House had a rendered cement-coloured finish for much of it's life (and certainly during the period that the layout is set in). Apart from modern Google-type photos of The Other House, there is hardly anything published. What would have been a good view in the above John Stretton book, taken in the 1960s, is mostly hidden by a rather inconsiderate pannier tank.
As such, the best we can do is to decide that The Other House was built of local stone, in a style that more or less matches other stone dwellings further up the Marsh branch, opposite The Fountain Inn, including the famous 'half house' that does feature in a number of contemporary photos.
I was then given a free hand to decide on the exact materials to use and the colour scheme.
Being a fan of the Scalescenes range of downloadable printed brick papers and building kits, I decided to use their 'TX48' sheet 'Squared Rubble' for The Other House -
https://scalescenes.com/product/tx48-squared-rubble/
The first thing was to produce a scale drawing to 4mm scale. As this was started when pandemic restrictions were still in place, the dimensions had to be estimated from what photographic evidence was to hand. A drawing was produced and a few copies taken. One of the copies was used to cut out the main wall elevations and lightly tape to a piece of Dalerboard (stout card, coloured on one side and 1.5mm thick):
A 4mm 'plinth' was left, so that the building could be slightly sunk into the ground.
The outline of the elevations and the window and door apertures were then carefully drawn around with a sharp pencil:
The five wall sections (including the end wall of the 'lean to' were then cut out.
At this point, I forgot to take any photos for a while.
I had the stone paper printed off by a local printer on his fancy laser jet, not trusting my aged ink jet to produce the kind of quality I was looking for.
The stone paper was then cut approximately to size and glued to the respective Dalerboard components and the resulting wall sections placed together for a photo:
The stone paper is overlapping at the corners and would be carefully trimmed back and coloured with a soft pencil, once the wall sections were glued together.
Next was to fit windows and doors. We had planned to use York Modelmaking products, but we couldn't find anything that matched the necessary window and door dimensions, so I made up window frames and sash units in the same way that I have for the Callow Lane cottages, namely individual strips of painted plasticard, which are glued in place behind the window openings and individual sash sections, with the glazing bars applied using a Bob Moore lining pen and enamel paints.
Some flat sections of plastic strip were primed and sprayed with a dark green:
A front door and also a side door to the 'lean to' were made up from plasticard:
In reality, the 'lean to' of 'The Nook' these days appears to function as a garage, with an entrance slightly lower than the front door, but for the sake of a quiet life, I have kept everything on the same level and assumed that in the 1950s and 1960s, the 'lean to' was simply a store of some kind.
Window frames and front door in place:
Sash window sections being prepared:
Windows and doors now glued in place. Front wall is still not attached to the rest of the building at this time, to aid fitting the windows and doors:
Now it's all glued together:
Next, a 'false roof' was glued between the various wall sections. At 1.5mm thick, Dalerboard is really too thick to stand proud of the walls:
Top roof sections were then cut out of much thinner card ('postcard' thickness) and parallel lines drawn on, 5mm apart:
Scalescenes individual slate strips (from one of their terraced cottages kits, which I already had) were cut out, the edges coloured with a grey felt tip pen and glued in place, using Prittstick, one at a time. When each roof section had all it's slate strips in place, they were placed between two sheets of clean paper and left overnight under a pile of heavy Ian Allen railway photo albums (other publishers will also do):
More to follow.
