After a early morning yesterday, for a day in a client's London office, I was also awake stupid early this morning. Decided to make the most of the time and do some more on the buildings.
So, I started by digging some 20thou out of the stash. Not sure how long I've had this but it's not been 40p a sheet for some years...and I don't think Mercian Models is around anymore!
In my now usual method, the 20thou was cut in to ruler-width strips and those were applied in a lattice to the roof formers. Photos show work part way through...
So a couple of points to note with this method:
# the first layer of horizontal strips sit inside the perimeter walls. This provides something for the wall to rest against.
# the top of the perimeter walls are then filed flat to the top of the first 20thou layer so that the join is flush.
# the use of strips enables access under the plasticard to apply solvent. It's a bit tricky trying to glue down one single sheet covering the entire roof and in the past they have come loose.
# the vertical noggins between the roof formers are deliberately cut short. This enables access for a glue brush underneath. It also provides an escape route for solvent vapours.
# the gaps in between the first layer of strips aid getting solvent to the joint between the lower edge of the strip and the vertical former.
# the next layer of strips runs at 90deg to the first and butt up against each other. These strips go over the wall edge and provide support to the tiles. This second layer also uses up the offcuts from the first and second layers, so very little waste.
# the roof will remain a separate, removable module which enables continued access to the building interior for window fitting, painting, detailing and future repairs.
This method is particularly good for forming uneven and sagging roofs, like on the grain store and wharf buildings. The roof formers can be cut to different profiles and the first layer of strips easier take the shape. The gaps between the first layer of strips help the strips curve and bend to the profile.
Depending upon the degree of sag, the second layer of strips may need the edge shape adjusting to form a butt joint. The result though is a tough roof that will keep it's shape and not come loose over time.
Any thoughts on this approach from others? Experience of other methods?
