7mm Pete’s GWR workbench. Dean's goods. RR R1 class 0-6-2T
Peter Cross
Hi Pete , i purloined one of these after my wife got it as a freeby from one of those shopping magazine's. I find its easier to mix the goop at the bottom of the tin/ jar first then use the electric stirrer to finish off otherwise it just stalls .
Ref the brown paint over the cream , i think you may find the cream actually covers easier but let us know . I model LNWR and after reading Larry G on this site decided when spraying some coaches to spray the plum first then the spilt milk ( white ) second . It covered the plum easily whereas the plum needed quite a few passes over the grey primer to get a a decent coverage .
That's interesting to know, bit late for this one. But I will let everyone know when I mess it up.
Peter Cross
If you can, there is an internet image of the GWS K14 interior showing the pink walls/ends.
I have spoken to both Pete Speller and Mick Howse about the colour and the consensus is that the chosen shade matches paint layers found during restoration.
I'll see if I can find the picture, thanks.
Peter Cross
Masked and sprayed the brown. It covered better than I feared.
Now can I call it finished before I mess it up completely.
Not sure if I will be able to the black tomorrow, as I have to go for yearly check up, and there are domestics too do as well. So it will probably be Friday, gives it more time to cure, always a good thing.
Hope I'm right, I have assumed that in the 1920's and 30's the ends would be black.
Peter Cross
Just a quick question, in the 1922 GWR coach livery, was the brown lined out as well as the cream, as per the earlier chocolate and cream livery?
Peter Cross
And then there was black.
Unfortunately I had a little brown paint lift with the masking, I'm sure with a little sanding it can be patch paint.
As it goes I am happy with it. My decision now is whether to go with the 1922 livery or the 1927 one. The 27 is by far the easiest to do, but the 22 looks good.
IMG_20220320_100337161_resize_70.jpgIMG_20220320_100329775_resize_59.jpgIMG_20220320_100308020_resize_21.jpgIMG_20220320_100354054_resize_16.jpg
Now back to something I know how to do, cutting metal.
Peter Cross
The lining had begun. I started with s yellow, golden colour, but against the cream it seems almost invisible, at least in the light I took the photo.IMG_20220403_122733514.jpg
I was happier with the finish on the cream, I expect I should of given it a coat of gloss varnish as the brown is a Matt finish.
Anyway, I added the black to a portion of it. I need to sort out the lining on the brown, I'm not happy now the blacks on.
I think I can tidy it using a bit of brown to thin the yellow down.
Peter Cross
I've done some more to this. I've done the second side in yellow/gold, it is an improvement but not as good as I hoped.
The other side I've completed the black. And there are a couple of bits I should of researched before starting not after. I need to do some more tidying up with the yellow and brown. I was pleased the way the black went on much better than I'd thought.
I think in the end it will be passable at normal viewing distance.
Peter Cross
The second side has had the black done, and a little other touching up.
The first side has had quite a lot of retouching, I think it's looking better. I will check tomorrow with fresh eyes.
Now I am thinking of transfers, I know it will have GWR on the duckets, luggage and guard on the doors. But does anyone know if it would have crest applied with the 22 livery.
LarryG
I no longer have the relevant book on early GWR coaches, however, I think it doubtful this elderly non-passenger carrying carried GWR 1922-28 livery. It probably carried brown or maroon livery from 1908 to 1922 right through the early years of the post-grouping GWR while the new fully panelled 1922 style chocolate & cream would have gone on passenger coaches first. It was a short-lived livery and so I think it likely this coach went to the simple 1928-40 choc & cream or even all over chocolate. Its withdrawal date might give some clues.
Commendable, Peter.
Lining is something I’d like to try eventually, with a pending investment in a suitable ‘pen’. To this end, I’ve been fascinated by a helpful video or two by Mike Trice which can be found on YouTube
If you’ve seen it, please forgive my interruption, but one measure I recall from watching was his use of a ‘new’ tin of paint (Humbrol) for each subject to ensure a compatible flow of paint. Respectfully Peter, I only mention this as I can’t help noticing that the tin of paint you appear to have been using, from the photographs anyway, looks as though it may have been in your possession for some time?
I sincerely hope you don’t mind my interjection, but just an observation.
I suspect that new tins of Humbrol paint aren't the easiest things to get hold of in Brazil. Mind you, they aren't easy to get here either (and the recent quality can be a bit suspect).
According to gwr.org. uk, the garter lasted until the '27 livery change then the twin crests came in.
Peter Cross
I've actually loads of unopened tinlets I used to sell them. But most are ex China manufactured. And no better than older open humbrol, and precision paints.
Peter Cross
Commendable, Peter.
I will look these up, I've not seen this but, have Rathbones book and videos.
Peter Cross
The end is getting closer. Today a bit more tidying, and transfer application. I have numbered it 899, which as far as I can see was the last to be withdrawn. I will now give it a few days to settle, then give it a coat of varnish. Once that is done I can get on an do the cleaning, floor and partitions. Maybe even some salmon pink inside.
Here's the first side.
Now the second side.
This is about as good as I think I can get it. I dislike painting, it seems to take up far more time than some of the construction.
Deano747
View attachment 160557View attachment 160558
View attachment 160556View attachment 160559
A lovely job, Pete, on what does not appear to be an easy project. Well done!!
Regards, Rob.
