Simon,
I did think of that, but too late, and I’ve put it all together now, so prefer not to dismantle again, as something seems to get damaged every time - the steam heat pipe and one rear lamp iron already need remedial action.
What I can do is add some photos of the bits & pieces I used.
The battery is a 300mAh 2s LiPo. I bought them here
GNB 300mAh 2S 80C LiHV Battery (XT30)
mine have a smaller 2-pin power connector, not the chunky yellow one in this picture.
the loco has a removable smokebox door and battery slides into the smokebox with the connectors at the front. I will remove the battery for charging. Hopefully the smokebox door will stand up to the handling. I’ll get a brass dart & handles, and epoxy them in, which will be a bit stronger that the original plastic ones which the instructions insist should not be used for removing the door - a fingernail under the hinge is the approved method.
the switch is a sub-miniature toggle, mounted on a piece of brass to lift it up a bit, thus reducing the length of the toggle showing. The footplate of the Dapol loco is a Mazak of some description, and about 5mm thick under the tanks. Apart from drilling a clearance hole for the toggle and a 10BA tapping hole to the screw, there was no other modification to the loco chassis or body. I cut the pickup wires short, and taped them in place, it’ll be fiddly, but I can revert to DC/DCC should I wish. If I did, I would not use the pull-out drawer that Dapol provide for the decoder, as that space is definitely better used for some extra weight up front, and a bigger speaker would go in the firebox area.
the receiver is a Deltang Rx60/22, they are about 30mm long, 15mm wide and 5mm thick when shrink-wrapped, and wired as shown in this pic from the Deltang website. Trouble is, they are no longer available. Andy at Micron is sourcing a replacement. There are some suppliers with stock, but it has become a wild goose chase, which is a PITA since the solution works. The receiver has 5 switched outputs as well as the ESC, so could drive a sound unit or lights, but I have not bothered at this point.
The Dapol motor, etc, was not modified, except to replace the broken wiring I put a plug & socket between receiver & motor, simply because I had them, it could be wired direct. It occurs to me that there might be a good argument for a DPDT switch in the motor leads to be able to reverse it to suit the layout, so the loco goes in the direction the knob is turned in, rather than clockwise-forwards.
The switch is in the positive wire from the battery plug to the receiver.
There is no arrangement for in-situ charging, as it would require a balancing charger, or a battery management system - the latter can be done reasonably easily, but I’m not sure whether I’d bother.
forgot to mention, even limited to 7.4V, and with the added weight in the smokebox, it will still wheelspin if overloaded or driven into the buffers, so no likelihood of burning out the motor.
Atb
