Re: Easybuild 105
Ressaldar
Easybuild 105
Coming together nicely - could not the rubber be lazered onto the glazing somehow and rebate the back of the rubber area to aid the fit then secure into place with canopy glue.
Jordan
Mid-Western Thunderer
Easybuild 105
28ten said:
If you know the area ... Lydney> Parkend> Coleford > .....
A rather fine area of the Country, that... :thumbs:
I don't think I'm fit enough to cycle that bit, let alone all the rest..!!! :eek:
Then again I was never much good on 2 wheels... probably why I spend most of my time on 14 of 'em these days.... :))
Sorry... back to the thread............. :-[
28ten
Guv'nor
Easybuild 105
A rather cruel enlargement  :eek: showing the headcode glazing in place although it still needs  a little tidying and tweaking.
This weekends phrase is 'assemble the body'  three little words that will probably involve 2 nights work  :))
Dan Randall
Easybuild 105
This would appear to be a "not so easybuild" kit....  ::)
Looking good so far though.  Keep it up Cynric!  :thumbs:
Dan
R
Rob Burge
Guest
Easybuild 105
Where do you get your thin acrylic from? I need some <= 1mm, not for windows but I want to make one of my signal box kits totally in clear acrylic for display purposes.
Thanks
28ten
Guv'nor
Easybuild 105
Thanks
I got a load of offcuts from a local supplier, just be prepared for the price if you want .the good stuff, Im currently trying to track down a decent source of 2mm mdf
28ten
Guv'nor
Easybuild 105
I has taken me since 11 this morning but the body is assembled  8)
the white bits you see on the cab and under the cantrail are 10thou plasticard which will be sanded to form a smooth join as there was an unavoidable step between the cab and roof
28ten
Guv'nor
Easybuild 105
Wax on, wax off.  wax on, wax off. wax on, wax off..... :))
I couldnt resist chucking it on the chassis, and whilst it isnt going to be the greatest ever finescale model it is starting to look like a 105
28ten
Guv'nor
Easybuild 105
An early morning alarm call (thanks boys  :headbang: ) say a blast of primer in preperation for picking out the smaller blemishes (you can see I have started on one).
Its looking good for a shakedown test on Heyside next week  :))
Ressaldar
Easybuild 105
hi Cynric,
looking the business now.
Is there any chance of a close-up of the filler caps that fit in the bodyside? as I think that they may be similar to those fitted into the sides of the Sandite units. If so, I might be able to get Shawn to include some in the kit that I am about to order.
28ten
Guv'nor
Easybuild 105
Ressaldar said:
hi Cynric,
this one?
Ressaldar
Easybuild 105
Hi Cynric,
many thanks for taking the trouble of taking the photo, but I thought it was this one-
28ten
Guv'nor
Easybuild 105
Progress continues....
the body is almost ready with just a few small blemishes still to correct
28ten
Guv'nor
Easybuild 105
Most of the large underframe castings have now been added, and as they are rather heavy most of them have been glued and pinned/screwed in place.
