Cheers Ken.Keep up the good work Mike, I think we all know what you mean. you
may want to run a bit of super glue round the connector pins though [not the connection]
Ken
Who wants to be a millionaire? Mike does!Why? Well, apart from being able to buy the odd mansion or two, maybe a yacht and a fleet of Lamborghinis I'd be able to afford to commission a set of milled 9f valve gear. But, alas I am somewhat fiscally challenged, so I'll stick with soldering many laminations of nickel silver together to create something resembling the real thing in miniature.
I'm not a great fan either - unless he's changed his production method the last set I saw he was using an end mill for the fluting so there was no flare out at the end and it just looks wrong.All that is gold does not glitter.
I got a set of milled Premier Components coupling rods, conn rods and valve gear for my 9F build (yet to start!) and I'm not all that impressed.
They are beautifully cut out and fluted, but they are all flat and the same thickness. The union link, for example, should be a 'dog bone' shape with forked ends. The PC part is just a flat rod with holes in the ends.
I'll probably end up using parts like the connecting rod, which is flat, but making those bits with forked ends from the DJH kit etches.
Mike, and others,I've found and ordered something I think is suitable off eBay. I shall report back in due course as to suitability.
Hi IanMike, and others,
I'm now using pre-wired micro JST connectors.... Micro JST 1.25 Connectors 2 Pin 2/10 Pairs Male Female Plugs Cables Wire | eBay
Ian
I'm sticking with the valve gear as per the frets provided in the kit, with a few Ragstone parts sprinkled into the mix. I'm sure the MOK parts would do the business, but I really need to reign in my spending on the Crosti. I've given up keeping a tally!Might an approach to Dave Sharp of MOK be a good thing?
OK, not milled motion work... probably all nickel silver castings so ought to be 3D.
Looking forward to seeing your 9f project!All that is gold does not glitter.
I got a set of milled Premier Components coupling rods, conn rods and valve gear for my 9F build (yet to start!) ...
Definitely an option. I've been largely lucky so far with my soldering by using oil, marker pen and chemical blackener to prevent solder getting in the wrong place. But I think my luck may run out at some point!How about drilling out a small brass nut to be a close fit over the back of the rivet? Fill the pivot with oil and secure the nut with low temperature solder.
Hi Ken.you could make yourself a small rivet set and flatten the rivet
Ken
