Where there is doubt as to the solder used then leaded should be used as lead-free contamination of leaded solder is benign; whereas, as mentioned above, lead contamination of lead-free solder is problematic.
I hope that adds something useful to the thread and at the very least the clarification should be useful.
Steph[/quote]
So rereading it, leaded should be used for repairs, "as lead-free contamination is benign (Collins dictionary, kindly, favourable).
Lead contamination Etc. is problematic.
This could be read in two ways,
1] that you can use leaded for all repairs as the use of lead solder will be OK.
2] But if you use lead-free on a leaded joint you will have problems!
If that is the case, why will it be OK in one case but not the other?
In case 2, as lead-free melts at a higher Temp. it could break down the leaded solder and cause problems.
In case 1, the lead-free has already tinned the parts and will not remelt. A bit like when we use 180Deg. solder to tin the brass parts before using 70Deg. solder to attach W/M parts.
That's how I'm starting to read this, I maybe wrong.
So don't use lead-free on top of lead solder, full stop.
Better idea. Don't use lead-free at all.
OzzyO.
