JimG
Just a question on the level of detail that can be reproduced by resin casting. As might have been seen in another thread, I'm investigating making masters for an S scale model of a 12T BR van with the intention of making resin castings from them. I'm not intending doing the casting myself but probably using a firm like CMA Mouldings to do the work.
What is concerning me is whether the steel section used on the sides of these vans will reproduce well in resin if made to scale sizes. The "T" shaped section on the prototype is 4" x 3" x 3/8". In S scale this means that the protruding 3" part of the section will protrude by 1.2mm/0.47" with a thickness of 0.15mm/.006" if made to scale. Would something like this be filled properly when moulding?
The diagonal "L" shaped section is even smaller, being 2 1/2" x 3/16" on the prototype, which gives a protrusion of 1mm/0.039" with a thickness of 0.75mm/0.003" on the model which could be even more difficult to fill.
I'm not intending to make a master of the complete body, but to have the sides and ends cast separately so that I can ring the changes on the sides (planked/plywood/mix) and ends (two panel/three panel/vent options) to make many versions of the prototype.
Jim.
Jim.
