richard carr
Having finally got the Heljan 31s to run properly its time to do a bit upgrading.
To the only really glaring error is the roof line by the headcode box, its too sharp, here's a photo that shows what I mean.
The defined line is just too sharp so I took a big file to mine to make it look like this.
I think this looks a lot better. It took just a few gentle strokes of a big file then a small file then some wet and dry paper ending up with 400 grit. If I polished it a bit more you would hard pressed to tell it had been done at all.
I have started to weather this one and the weathering will cover up the roof as that part will be oily black. I have also painted the handrails yellow as they should be. I have done the same on the green one but here it removes the grey roof to reveal the green below it.
As you can tell I'm not the best in the world at putting numbers on !
That might need doing again.
