Ressaldar
Hi all,
having made various threats that I was going to build one of these, I have just received the traction motors from ABC so there is now no excuse nit to start the build...............................or so i thought
Having unpacked the traction motors, I noticed that the 'stub axles' were stubby to say the least - barely 1.0mm long, so not much to go into the bearings. The overall length of the axle being 40.93mm, compared with the Easybuild axles - albeit over the 'pin-points' of 47.64
So the project has 'stalled' before it has started while I put the thinking cap on to work out a method to suspend the motors in the Wayoh bogie - some form of 'C' channel soldered onto the inside face of the front stretcher and a similar type of arrangement on the bolster - having first solved the basic bolster arrangement - hollow brass rectanglular tube would seem the way round it, but from the experience gained? when I built the MLV bogie, that has it's own little problem areas too.
However, it's something to think about as I enjoy the festivities and trust that you all have a great Christmas and New Year wherever you are.
