Next instalment,
drilled hand holes in doors…. Mmm, only two per side on the model, and only two latch handle per side too. I’m pretty convinced the original vehicles had latch handles on all four doors on each side, and four hand holes (so you can reach out and operate the latch if you get shut in), certainly on earlier lots. So far, I’ve drilled out two on each side and discovered the wagon is moulded in white plastic, probably explains the white inners for the corridor connectors. I touched in with a tiny drop of precision coach brown, fingers crossed it won’t react horribly. I think the hand holes are quite noticable, so I’ll probably drill the extra ones.
I‘ve now fitted the battery boxes, couldn’t find any hard info, so put a single large one centrally each side, looks like the photo on page 180 in Russell, and I’ve run some watered-down rust pinwash over the bogies. Once that’s all dried, I’ll see if another does of airbrush track grubbiness is called for.
I also removed the couplings, and the little moulded turret to which the spring is secured, blacked a pair of Premier screw couplings and fitted them, with the Premier springs, which are much beefier than the originals.
Photo later, when it’s dried!
