Stanier 8F in black.
I realise that it will soon be three years since I started this thread!
So I had better get on with it .....
This is the stage at which realism becomes more possible. I have now painted the locomotive all over in matt black. I will then add numbers and lettering, before applying an all-over protective coat, then add weathering to make it more realistic. It looks a little odd at the moment, because the superstructure is an even matt black, whilst the wheels and motion have a more weathered appearance.
Here are some pictures in still and video format:
These are "Youtube" videos of the engine running on my test track.
To the educated eye there are some mistakes visible, even apart from the lack of number and lettering, but they aren't too obvious, I hope.
There are no cab window frames or glass, some small parts remain the wrong colour (coupling hooks, etc). No coal in the tender.
There's also no exhaust steam injector below the left of the cab (it fell off as I was preparing the loco for the video - curses!).
The lack of a number is a source of one amusing difficulty at present. I built the locomotive to be a version based on the features which I liked and thought looked good, namely: riveted tender, straight reversing rod, long exhaust ejector (which only rules out the GW-built ones, of course), squarer-ended balance weights on the driving wheels, riveted front buffer beam. Ideally I wanted one based in the NW of England (I was born there, and wanted my colliery model based there, although this is not really important). Out of more than 800 engines, this shouldn't be difficult, surely?
This approach to picking an exact loco. to model is difficult. Looking through all the books I had, I couldn't find a single one with all those characteristics! Admittedly it is partly because if you cannot see the left side, you can't be sure of the reversing rod (or exhaust ejector), and if you cannot clearly see the wheels you cannot tell what type of balance weights there are.
However even after filing the rivets off the front buffer beam (riveted ones don't seem common) I can only find ONE picture of an 8F showing a straight reversing rod, a riveted tender and square-ended balance weights. So 8185 is the only one I can model at present, based in Motherwell.
Can anyone show me an alternative? Not that it really matters, I suppose.
Anyway, I hope you like the pictures.
David
