Has anyone got a set of the 8f S7 additional etches?
I got a set earlier in the week - unfortunately I'm away for the weekend so won't be able to post anything about them until Monday - if you can wait that long.
I don't have any drawing or photographic evidence to hand to confirm it but I think the back of the piston valve guide should be completely cut away. So that the guide is just a U shape rather than a box shape. That's how I did it on my Ivatt 2 and 4MT.So with some careful filing I have achieved enough clearance, but was there a better way around?
I think that I'd look at narrowing the motor mount and leave the footplate alone. Or have a look at the firebox front and see how that fits.
OzzyO.
I presume the problem is that the footplate is still a "finescale" item so the 26.5mm between inside edges is so that they meet the finescale chassis. I think the problem will be that the footplate will now overhang your wider frames and look unusual.As can be seen, the problem is that the upright frame for the motor mount has a width of 29mm, whilst the distance between the edges of the footplate is 26.5mm.
[snip]
I can easily cut a little out of the footplate and make it fit, but it would be mice to be able to predict what the final effect will be!
