So back to it in June!
The meat van if you remember the kit was minus it’s buffer beams so I made those from some plastikard. Also I lost a buffer so scratched one of those from sprue.
Next painted roof in Humbrol awful finish so needed a flat with some fine grade wet n dry paper.
Back early in the thread I was asking how to solve the stiff fit on the axles, I found a solution as you may have read earlier.
My patent tiny screwdriver to reem out the axle boxes!
Buffers painted with new matt black Humbrol that came out gloss finish!
Reading a fair bit on weathering and painting many modellers are turning to acrylics, after every paint session with the enamels the brush cleaning fumes were quite heady in the van even with the windows down! So I purchased some dead cheap acrylics to have a play.
The under frame painted Matt black it covered rather well
Mixed a bauxite likeness! Not anything like as good coverage as an enamel, but another coat guess mixed did the job. 1 coat below.
Referring to another of Paul Bartlett’s photo’s
BR Meat vans - ventilated & insulated | KDB870082 VAN
Black wash went on, not very accurately!
Holiday in North Wales, had a great time modelling in the sunny evenings! In the second photo just beyond the caravan is the Cambrian coast line so had a few trains pass as I was out there, nice that.
Ambis engineering coupling hooks made in a batch a while ago filed up and fitted.
Forgot the transfers, unbelievably still sticky after a float in water and 48 plus years in the box.
Ambis coupling chain made and fitted.
The number was to long for its position as noted on the photo I linked to, with hind sight I should of trimmed it but I just ran it up the metal corner strut. More black wash went on!
That’s my 15 photo allowance thanks for looking in more later or tomorrow.
All comments welcome.
Ade
