7mm Steve Fay’s layouts and dioramas
Discussion in 'WR Action' started by Compton castle, 25 October 2015.
  1. Compton castle
    Compton castle Western Thunderer
    I've cut the fur to size this morning given a good singe and wafted some mud brown and dark green over to give it a patchy unkept look.
    I use poster paints to dye the fur double the amount of yellow to green. It's a good idea to see how the green dries on its own on a piece of paper as you might want to darken it down a bit. I tend to find the green usually dries quite a few shades lighter than it looks in the bottle. I apply with my hands wearing an old pair of marigolds ( most fetching) if you get any clumping once dry then give it a good brush with a stiff scrubbing brush then singe it with a blow torch but very quickly. Depending on what type of grass it is you can add different shades of colours with spray cans but again wafting is better. Again if you spray to much then get the stiff brush on to it. Before you start vacuum the teddy bear fur as quite a bit wil come off.
  2. Compton castle
    image.jpeg image.jpeg image.jpeg A little more progress this evening,
  3. Ian G
    Ian G Western Thunderer
    That is coming on nicely.
    Ian G
  4. Compton castle
    5043 drifts down grade on a Plymouth/ Manchester. image.jpeg
  5. Compton castle
    image.jpeg Back to some track weathering
  6. Yorkshire Dave
    This is looking really good. Simple but effective :thumbs:.
    Compton castle likes this.
  7. Compton castle
    image.jpeg Extra flowers now blooming
    LarryG, Jordan, Rob Pulham and 2 others like this.
  8. Yorkshire Dave
    I had to take care when doing this on my layout to ensure gardeners/botanists could not say that I had flowers/shrubs in bloom out of season. It's as bad as us counting rivets :confused:.
  9. Compton castle
    First signal now complete all bar some weathering. I think you will agree Jon has done another Top job.
  10. Compton castle
    I built a peco GW engineers wagon today.
  11. Compton castle
    image.jpeg The bracket signal is rapidly progressing with Jon
  12. Compton castle
    image.jpeg More progress from Jon this evening with the bracket signal.
  13. cbrailways
    cbrailways Western Thunderer
    Don't forget the distant arm was motor operated (you can see it just below the arm) :rolleyes:
    Stumpytrain likes this.
  14. Compton castle
    image.jpeg I've planted a few wild flowers from the mininature range this weekend. Phil has started cutting the signal box so that should not be to far off now
  15. Compton castle
    image.jpeg The ARP signal box taking shape with Phil ( Intentio) this kit will be available to all soon. It's an austere design and one you don't often see modelled.
  16. cbrailways
    Thats good news as I need one for my Blackbridge Town layout :)
    BrushType4 and Compton castle like this.
  17. Compton castle
    Updates on both Severn tunnel east & Gaer junction, the Regent oil train is now complete minus a brake van & the engineers train has grown now the cat & dog fish is home. This will grow with the inclusion of an engineers toad and some Grampus. The best news is JLTRT are going to do a mermaid & sea cow ballast hoppers.
    On to Severn tunnel I've added some dirt on the down main plus the lineside equipment boxes. A post mounted box by the bracket signal and 3 lineside boxes behind the signal box, well 2 at the moment the 3rd is in the post. They need a coat of grime yet.
  18. Compton castle
    image.jpeg A little more scenic work completed today. Just waiting on one last order from a Polish firm Polak.
    Len Cattley likes this.
  19. Compton castle
    Stock for Gaer junction, The Barry Docks Geest Banana trains. Starting off with a BR JLTRT van kit. I do enjoy building these kits as they are quick to build. I can't go much further as I need to order the wheels.
    JLTRT are going to add the LMS banana vans and a few GW options as well.
  20. Compton castle
    image.jpeg Signal box kit nearly ready for Severn tunnel east, Phil has been working hard on getting it ready. Looks superb
