Do you ever get the feeling when you've completed some project or part of a project and you look at it and think that's great, its turned out exactly as I imagined and all the time spent has been really worthwhile ?
I often wonder what that feels like
................. I digress.
Anyway, as I plough my lonely furrow (nobody else is building a US narrow gauge layout on WT as far as I know are they ????), and after applying about half a ton of Polyfilla (slight exaggeration, but that's what it seems like) the scenery around the trestle is fully plastered - the rock formations and ground surface are all in place. Whether its all topographically, geologically or otherwise feasible in a real landscape I don't know, and quite frankly I don't care as I'm definitely not going to do it all again ! Poking, placing and smoothing the wet plaster behind and between the trestle bents has been something of a trial, and in retrospect it would have been better to place the trestle foundations, finish the scenery, and only then build the trestle itself. Fortunately the trestle woodwork has come through relatively unscathed so far, usually remembering to remove wrist watch before poking hand under trestle. There was just some splashes of wet plaster on the woodwork which are easily wiped off. However painting the rock and ground surface is a different matter so I'll probably have to cover all the woodwork with cling film before starting that - Oh, joy !
The rock castings are made from Woodland Scenics rubber moulds, 12 different ones being used in the process. The biggest problem I found using these was air bubbles in the plaster mix forming hollows on the face of the finished casting. I tried different mixes of plaster from fairly stiff to runny liquid - the latter taking ages to fully dry out; wetting the mould before applying the mix as recommended; vibrating the mix before pouring or after pouring in the mould to bring air bubbles to the surface, i.e. the back of the finished casting; poking it when in the mould with a sharp object to try to burst any bubbles; shouting at it; swearing at it; but never really solved the problem. Sometimes the surface hollows can be carved out or filled in, but at other times it was straight in the bin usually accompanied by more bad language. The plaster used was mainly Polyfilla but I did try Woodland Scenics Lightweight Hydrocal, the only noticeable difference was the quicker drying time of the Hydrocal. The rock castings were set in more Polyfilla and any gaps between the castings filled with the same. Prior to that the original surface whether it was wood, foam or plaster was given a coat of PVA adhesive, and the back of the rock castings were also coated with PVA.
I like to colour the plaster with water soluble paint to take the stark whiteness away and for the ground surface I used a cheap dark brown shed/fence paint. I should have added more paint as it dries much lighter than the mix and goes lighter again when its sanded to remove any knife or trowel marks in the surface. I have most of the 5 litre tub left, and its too dark for the shed ! Not that it really matters as it will be painted before I add the ground cover material. For the rock castings I used a black poster paint to add a light grey colour.
I need a trip out to some local river or stream to get suitable small pebbles for around the stream bed. For the ground cover, or "dirt", I collected material from disused mine tips several years ago, probably laced with traces of lead, cyanide, arsenic or other nasty materials, but the colour looks about right.
tbc
