Peter Cross
I hope not.Isn't there a check rail missing on the top right crossing?
Jim.
Jim.
What's the word I'm looking for? Oh bu@@er. Better check tonight.
Almost there. The buffer plank has now been added. It took a while as the 8 fixings all had to be the right length, with a hexagon filed on both ends.
We also have the right number of sleepers under it now. Over all I'm quite impressed at the way it's turned out. Time to look at other designs after this one's been primed.
View attachment 145989 View attachment 145990 View attachment 145991
l´ll bare that in mind. I was going to leave the last six inches or so of rail before the stop with a layer of rusty paint, which should insulate it all too.Very nice, Peter.
I take it that although the buffer plank is wood, the tie bar is metallic, thus electrically joining the two sides? When you leave insulating gaps to the adjoining powered track, beware of wagon wheel rims bridging the two gaps simultaneously, thus causing a dead short. This problem befell an exhibition standard P4 layout when, in one planned move, the wagons had to be pushed right up to the stop to get clearance. It took them quite a while to figure out the problem. To avoid the risk on my layout, I've added a second gap in one rail, staggered, so that both gaps cannot be bridged together. Just a thought.
Dave.
I don't think it will matter Chris, Slater's wheels are insulated and the rail is insulated from the powered track. As mentioned it's when the wheels cross the gap the problems can occur. The gaps in the rail I will stagger by a mill or so, which will mean the wheels will never bridge both at the same time. A coat of acrylic paint on top of the last few inches will also help.Would it be safer to substitute some plastic rod for the brass rod? You will end up with wagon buffers pressed against the wooden beam which will mean that the wagon wheels will be on the buffer track.
AlanPeter, I was wondering how easy will it be to fiddle in the fiddle yard when you have to lean across the station throat, I suppose it depends how high the layout is. The lower the easier to fiddle.
No apology necessary - we've all been there to one extent or another over the last couple of years. Just glad to hear from you again, check in again when you are ready.Sorry for lack of progress reports as there has been none, in fact no modelling has been done last July.
