Hello all,
this is the grit blaster that I use, it was bought from machine Mart, the cost at the moment is approx £150 including VAT,
The sizes in the catalogue are as follows, L580mm, W480mm, H490mm, to try and give you an idea the drawing that you can see part of is A3 in the vertical format. This is a view of the inside, the rule is 12" I also use a cheep splatter guard to stop dropping small bits in to the grit,
A close up of the gun, you have a chose of four sizes of nozzles with this one, 4, 5, 6, and 7mm up to now I've only used the 4mm one,
I've worn one out but it was still doing it's job,
One thing that grit blasters don't like is moisture so you do want one of these as close to the blaster as poss. approx price £8.50,
For connecting it to the compressor I use this type of connector,
One thing that you will need is a compressor that will produce approx 10 cubic foot of air per min.. The one that I'm using came from Aldi for appox. £80. 1/3H.P. with a 25 Litre tank.
For the grit I use aluminium oxide (180? grit) [Ebay is your friend] mixed with a small amount of 80 grit. The only reason that I mixed in the 80 grit is that the 180 is very fine and wares adding the 80 grit just adds a bit more more "cut" (about 15-20 ;1).
The air pressure that I tend to use is about 50PSI.
It is a photo of a tender that has just been built and grit blasted, some of the castings are white metal and it cleans them up very well, but don't dwell on them for too long as it may remove all of the detail,
HTH
OzzyO.
