The 'standard' tank engine wheel is 4'7", 14 spoke, Pin Between (PB) and a 10" stroke to match the inside cylinders which stroked at 24".
The answer may be found in Russel, vol.2. Page 228 has the Swindon weight diagram and this specifies 4' 7 1/2" wheels. The cylinders are specified at 17 1/2" x 24", so max of 24" available for stroke. On page 229 there is a photo of the valve gear which shows the leading wheel with a pin In Line (IL) and I think 14 spokes. So far, good for Sharman.
However, Sharman lists the 15xx as a 1949 design by Churchward! It was, of course a Hawksworth loco, with drawings listed in 1944 and 1948 and took a lot of the design from the 94XX. The 94XX is listed in Sharman as having wheel attributes simsilar to the 'standard' tank engine. I find the Sharman listing of a 24" stroke for the 15XX strange as there is no previous 4'7" wheel with that attribute. This implies that at a time of finiancial squeeze that there was money to design and build a new wheel. To back the 24" stroke arguement, the weight diagram in Russell is supposedly scale at 4mm and the wheel stroke matches 24".
To further complicate things the 94 is listed as PB but there are photos of 94s with IL wheels.
So, I would say 4'7 1/2" wheels, 14 spokes, stroke as available in model form and a photo of the loco being modelled to check for PB or IL. Or there is Rule 1, it is your model!
Did I say the answer could be found? Stupid boy!
PS. There is a Swindon GA listed at on the Swindon Drawings list at York. No 124595 on film.
