Whilst this question is driven by current work with 7mm track there is a fair chance that the question is relevant to other scales where the track is handbuilt / uses ABS fishplates.
Handbuilt track and turnouts in 7mm, using Exactoscale ABS fishplates, means that there are many "droppers" to be connected to the DCC power bus. In the past I have used the two insulated cables from "1mm twin and earth" for the power bus with the bus underneath the baseboard and following the route of the track - droppers from each section of rail are then soldered to the appropriate bus cable. Whislt this approach provides a workable solution I am not sure if a power bus under each line of track is the best way of doing things.
The current 7mm layout is roughly 3' wide, about 25' long, with four tracks across the board. The baseboards have full depth cross members every 15-18" with lightening holes in the cross-members.
For those of you who have wired a DCC layout, what are the options for routing of the power bus and connecting droppers to the bus(es)? How do you secure the power bus(es) to the baseboard?
