so Ive built several kits over the last few weekends ... all flatpack furniture though
finally had a spare 30mins and a cleared desk this morning to have a quick play with the spare etches and have learnt a few things:
1. my cutting mat melts much easier than I thought it would
2. the 8" bending blade was £1 well spent
3. the BOGO safety flux is truly wonderful stuff
4. taking pics of shiny brass with an iPhone is really tricky
anyway, my first ever bit of brass soldering:
This is with Multicore 179deg and a quick swipe with the fibre brush (mostly to remove the multicore flux blobs). It turns out Ive been using Sn62 all these years and not standard 60/40 as I first thought, and it flows beautifully with the extra flux and stays shiny even after reworking. At ~£40 a reel it flippin well should! Hard to tell from the pic but up close it looks like a mini seam weld, I'm pretty chuffed with it
I also folded one of the spare pieces over completely and used 145deg to laminate it. The flux really does seem to suck the solder into the gap and the Maplin iron had no problem even with the piece clamped in a steel vice. No pic because after a quick file on the edges it just looks like a single piece of brass, but thicker.
Having a play with the riveter punch now. Theres no spare bits with half-etched rivets to try it on but I think I may have to file the point down a bit as Ive gone through the spare fret brass a couple of times.
Jon
