7mm Loose Ends
28ten
Guv'nor
I think that I must have missed the discussion on this point... if possible can you please provide a reference to the original post.
It may be something Steve Harrod and i discussed, but as supplied the angle on the frame is way to prominent, so I went in with the sanding stick ;) it is one of those things that would be better etched.....
28ten
Guv'nor
Fingers crossed I shall be able to start looking at the truss this week, which might interest a few of you about to hack EZB underframes which I believe are plastic :) I want to finalise the mods for this before doing the photo tool for the bogie as I may well wish to add a couple of bits.
Railwaymaniac
I need to make sure all the buffers and kaydees line up for these coaches, so its jig time. Very simple, the holes are the correct height and spacing, I could probably turn something to fit the holes, but its pretty self explanatory. I would imagine something similar would work for auto couplings.
Adding the three bits of brass for this jig would be nice too, please? :thumbs: :thumbs: :thumbs:
Ian
28ten
Guv'nor
I have a headache from banging my head against a wall :headbang:
I started looking at the truss and something looked wrong so I measured up and compared to the dwg in Parkin, the gap between the L should be 2ft (14mm) and this aint :rant: its 10.2mm
I dont know if anybody else building these kits ever noticed it, its something else I could add onto the bogie etch, although I could just fabricate them from brass angle using the chop saw and an mdf jig.
This isnt supposed to be a super detail build now I know there is a problem it cant be left. :rant: Christmas 2020 at this rate and the underframe needs to be sorted before the body can be started.
Railwaymaniac
Not good. And I'm quite surprised that NQLTRT would make a mistake like that. . . :(
The parts on the Easybuild kit are a nominal 14mm across there, so what they supply is right (whew! <relieved>), although following discussions on here I'm also considering throwing the plastic bits of the truss rodding in the spares box and using brass angle instead.
What 'chop saw' have you got, please? - I'm due to pay a visit to Axminster tools tomorrow to look at some form of cutting tool for use on this task.
Ian
28ten
Guv'nor
Proxxon KG5o. it was about £80 when I bought mine. Brass angle will give a more robust job, it all depends what you want, although I used brass on the EZB's.
28ten
Guv'nor
A quick visit to Mr laser and a few ideas on making jigs. Firstly I thought cut and lay the brass, but the a better idea on the right is to use the angle to support itself and cut narrow holes to give firm support. The jigs wont last long but that doesnt matter, something similar for the longitudinal angle will also be needed, but im planning on using the kit parts for that.IMG_0805.jpg
The chop saw awaiting instruction - note the bin in close proximity :))
28ten
Guv'nor
Having drawn up the truss, more jigs have been lasered, in this case for a GUV. all the angles are marked ready for the chop saw. After this test I will cut the parts for all 8 underframes.
It would be fair to say im Mr Grumpy after having to do all this.
28ten
Guv'nor
I dont know yet Phill, whatever fits! Im not worried about uncoupling just being able to rail the coaches and push them together.
Much cursing and swearing has produced a representation of the truss. All this is from old school strip and L angle. I know what I need to etch for the main batch and the arts will fit along the edge of the inner bogie etch. The most important part is that the whole lot can be securely fixed with glue and screws to the plastic chassis floor.
To show solidarity with Mike..... next step some paint.
Whitemetal axleguards notwithstanding, that is a very nice looking chunk of Fruit D-ishness:thumbs:
I haven't got the motivation to get back on to my brass version yet, plus I need some brass strip for the bottom edge of the solebar.
More positively, Captain Kernow is lending me his resistance soldering unit this weekend, so I'm going to attempt the PMV as well.
28ten
Guv'nor
The body is a lovely moulding but the chassis is less lovely. Id would like a bigger one though :)
Leave the PMV or I might feel inclined to get mine out ;) I had some more photos arrive for Wallingford today including a very useful view of the station from the forecourt.
Ressaldar
many thanks for the 'heads up' on the Fruit D Guv, I had little time yesterday to do much - just got the trusses done before going to the Club. It's 'taking Aged Auntie shopping day' today, so again there will not be much progress, but hopefully enough to get the camera out at the end of it.
28ten
Guv'nor
After some 'language' as my mother would call it.......
the bogies are not fixed, and it will be fitted with my sprung units
I have built a couple of MMP GUVs as well as this and i wouldnt say this is the easier one to build...... but it has given a lot of pointers for the Mk1's, and Im confident this will look the part on a large layout.
As an observation, whilst the MMP is the 'king of the hill' for fidelity and accuracy, there is no clear leader in the middle ground for a simplified Mk1 designed heavier running.
Another visitor awaiting conversion to battery operation, posing with a little friend:)
tomstaf
This all looks very interesting. The trussing is something I'll have to remedy on my RMB - grrr. Btw, the GUV sits quite a lot lower than the Western. Is the GUV meant to be lower or is it an optical illusion?
Tom
Phill Dyson
Inside framed vertical planked Syphon G is one parcels vehicle we could do with in the larger scales :cool:........strange that manufacturers duplicate stuff like Guv's when there are obvious gaps in the market :confused:
