I had a quick look at the interior at 5.30 this morning
the kits come with some nicely laser cut partitions, but if you want to fit glazing into the corridor partition then there is the problem of seeing glazing sheet inside the partition. Its a fairly common problem that you also get in some etched kits unless the designer has used an inner skin for the partition. So what can be done?
MDF partition and press fit glazing. using one of the little quirks of lasering ( a slightly tapered kerf ) the glazing can be pressed securely into the taper without needing glue. The crude diagram below shows what I mean
Applying the theory from the outside (only the middle partition is glazed btw)
Without the side
and from the corridor side, hopefully you can just see the reflection.
The downside is that the glazing is slightly prismatic, but Ill live with that, as I feel its worth it for being able to apply the no smoking transfers to the glazing. Im happy with the concept and it takes all of 10 seconds to glaze a partition.
