Down the shed, protective covering put on workbench, nitrile gloves on and out with the resin.
Poured out into two ex Bristol University library plastic water cups (with Eddy the porter's help I collected a lifetime's supply from the recycling bags when I worked there) marked for volume, one poured into the other, mixed up with a stick, poured into mould (strengthened by plastikard "cheeks" masking taped on to two of its sides), fine detail poked with fine wire through resin to try and clear any bubbles, inner plug mould inserted and held in position by hand until the resin started to "gloop". I'd mixed too much (about 80cc I think) and so had to "comb" excess resin off the top of the mould until it was sitting fairly level. After the resin had solidified a bit more I could remove my fingers and look at the result, still not cured so I set about cleaning up all the spilled resin from my plastic sheet (old "soapy" finish carrier bag opened out) covered workbench.
When I'd finished I took the plunge and removed the cast from the outer mould....
Looking quite promising I think, I'm going to let the resin go of for another hour or so before taking it out, the first stage of which will be removing the plastikard core from the rubber plug mould.
It will be interesting to see just how accurately I got my "pads" to register with the various openings, you can see some blue colour behind the resin in and around the windows and I think there are grounds for optimism on this point.
Of course what can't be seen is whether there are any unhelpful voids or air bubbles, although the surface detail has all been picked up perfectly as far as I can see.
I'm off out tonight and will see what it's like later, but on the whole I'm very chuffed with the results so far
Yippeeeee!!!!!!
