JimG
Are you experimenting with the body sides already built up? I would be very interested to hear more of your experiences.
Jamie,
I'm doing the chamfering when I'm milling the sides. I've just started modelling a Drummond Caledonian Diag.5 brake van - yes, another brake van which was started on paper before yours and Steve's appeared on here.
The curb rail of the van has a series of bolts or tie rods along its length with chamfering in between and I wanted to try and reproduce this. I was also looking ahead to the modelling of some Caledonian vans which have heavy outside bracing with chamfering and this would be a good test bed for methods.
I've used a 2mm ball end slot drill and positioned it to cut at 45 degrees with a depth to match the dimensions of the chamfer as near as possible. The results look good and the ball end mill gives a nice transition at the ends.
As usual you can hardly see any detail with white Plastikard so I messed about on IrfanView to accentuate the chamfering.
...which makes it just a bit more obvious.
I had thought of using a 3mm ball end slot drill but thought that the increased diameter might be a problem when dealing with the cramped conditions at the top of a diagonal on a van side.
At the moment there is a pause until I investigate a method of engraving planking to do the inner sides of the verandahs - just waiting on some engraving cutters coming from China.
Jim.
