JimG
I've just been salvaging some Code 80 FB rail from an S scale dog track I made many years ago. I'm intending using the rail again on another piece of S scale track. The original track had the rails soldered to PCB sleepers so there was a fair bit of solder left on the rails after separating them from the sleepers. I like using clean rail when tracklaying since blobs of old solder always seem to fall in the wrong places and you waste a fair bit of time doing the cleaning while tracklaying.
So I set about to clean the rail with the soldering iron and my solder sucker - my usual de-soldering tool. However, the solder sucker doesn't get the rail really clean and I started searching around for an alternative that would be practical for cleaning up ten yards of rail. Then my eyes fell on my glass fibre stick which was going to be used to polish the rail after de-soldering. It is glass and won't melt at solder temperatures, so worth a try - and it works really well. I find that it works best when I put the tip of the soldering iron on the solder to be removed and place the glass fibre brush next to it. Then when the solder melts, I wipe the brush quickly across the solder, moving the soldering iron tip in the process. I am using a 12mm diameter bundle of fine glass fibres - I don't know if the coarser, narrower diameter ones will work as well.
I haven't ever seen this method suggested anywhere . I think it will work best on relatively flat surfaces where you have got room to sweep the brush across the solder. For nooks and crannies, I suspect that a solder sucker or copper braid will probably be better.
Jim.
Jim.
