Steve Cook
Some more brass bashing today, but with larger bits, so less swearing and moaning about it
Some U shaped brass strip was cut down its length on its back, then 2.5mm strips cut off the ends. With a bit of clean up file work that gave me 4 L shaped pieces to represent the cast lamp irons for the veranda corner posts on the brake van. Some 0.5 etch was filed, drilled and cut to length to give me four bases to attach to the posts.
The L shaped pieces were soldered to the bases with short lengths of 1mm rod added to represent the fixings and give me pins to glue into the resin corner posts. A quick scrub and they were dunked in chemical black - as they stick proud from the body I can see them getting caught quite easily and the paint isn't going to last well.
With holes drilled into the corner posts, the brackets were superglued into place - I'm hoping the glue will yield before the post in the event of it catching anything, or indeed prevent the van from being dragged off the track. I really hope I never have to find out though
I have no idea what the blocks under the lamp irons are for, but they've been made from 2 x 2.5mm Evergreen strip, glued in place and then had 0.5 rod stuck into holes for fixings. A set of replacement rivets were made and dropped into the holes in the arrow brackets too.
I reckon I'm about 95% done on the fabrication front, its time to start gluing all the relevant bits into place There are lamp irons to be mounted on the ends - I shall solder the rivets in place and drill suitable holes, but again they are vulnerable so will probably be the last job before primer. There is the small matter of the horizontal handrail to content with but having read the instructions, I've prepped for everything else mentioned and finished my tick list, the air will be thick with the smell of Araldite this week then...
Steve
PS Apologies for the over use of the 5 pence piece this weekend, it just makes explaining the size of things much easier to work colleagues on a Monday lunchtime.
Steve
Steve
Steve
