Genghis's 7mm Workbench
Genghis
I would usually have ensured that I have a rolling chassis before doing anything else, but I realised that the larger diameter holes in the coupling rods need opening out a fraction so that the head of the bush fits in fully. I've ordered a slot drill so while I wait for that to arrive I have made up the footplate. This would have been the next job anyway as I like to check how the motor gearbox is to be fitted. With that done I will also need to work out where to fit the pick ups as the frames do not have any pre-existing locations marked out. There were lots of rivets to emboss on the main section of the footplate. This is where I am now:
Genghis
The slot drill arrived so I was able to complete the coupling rods. The bush sits nicely inside the boss.
I decided I wasn't happy with the front footplate, so after wafting the meringue browner at it I was able to rebuild it and add the other parts of the framing that stiffen the footplate assembly.
So back to the frames tomorrow. First to check that the chassis rolls nicely with the rods on and then to add the motor mount and mark out the locations for the pick ups.
Hi David,
Nice work with the slot drill, and a useful alternative to the process I used with a mini-CNC mill.
do you have any photos of how you held it whilst you machined it?
atb
Genghis
Hi David,
atb
Not ideal.....
As the holes were nearly there and only needed a smidgeon removal, I could line up easily. I half expected to have to raid the stores for another set of rods but luck was on my side.
spikey faz
Hi David,
atb
I'd be interested to know more about this process as well, please.
Genghis
Really not much to tell. I have a Proxxon milling machine which mostly gets used as a vertical drill. The slot drill was set up in the chuck and the workpiece lined up by eye and feel: gradually moving the stationary drill down until I was confident that it was aligned with the middle of the slot. What I should have done is clamp the coupling rod close to the boss onto the X-Y table and then line it up. As I said above, because the rods already had a near correct diameter hole and a very small amount to machine out, I took the risk of simply holding the workpiece and then switching on the mill at maximum speed. Gently lowered the cutting edge and quickly move it back up again. There was less than 0.5mm to take out but I needed a flat surface which of course you don't get with a normal drill if you don't drill through a piece.
David
Ian@StEnochs
David,
A slot drill is not ideal nor very easy to set up accurately to counterbore an existing hole. For countersinking crank pins I use a spot facing cutter, 5/32" with a pilot, which locates the cutter exactly on the same centre as the existing hole.
I have put a brass bush on the pilot pin which fits the predrilled hole in the rod.
Held in my drill press with the rod held down by hand it needs a light touch and a bit of cutting fluid but leaves both hole and counterbore perfectly concentric.
Ian.
Rob Pulham
Thanks David,
I have had to buy imperial sizes from Drill Services to get the 'metric' size that I wanted on occasion too.
Genghis
David,
Ian.
I think your solution is better. Fortunately for me the outer laminations of the coupling rods and bosses were already the larger diameter, so alignment was pretty automatic.
David
