Lathes and M/C tools.
OzzyO
Hello Rob, all,
please do put a thread on here. When you do drop me a line so I'll know where to look.
ATB
OzzyO.
OzzyO
Hello all,
not that much to say at the moment as I'm waiting for materials.
So I've been drawing the mounting plate for the reading head on the Z axis. This is where it will fit, It looks like the scale is out but it's just parallax? error the scale is within one or two Thou over 12".
Measuring for the plate it's going to be 3" high and 23/4" wide by 1/4" thick. I'm going to have to remove 5/32" from most of the bottom to account for the step for the ring.
You can see where the step is on the top of the mounting ring. the clamps in place to see where the cover for the scale will fit.
The cover clamped in place.
As luck has it there are two M5 holes that just need a tap running through them and I can use them to mark the centres of the M4 holes for the fixing screws.
After turning the big aluminium job I decided to get some tips that are for aluminium and non-ferrous metals. These cut the shim tubes absolutely brilliantly.
After all the testing for the cover for the Z scale I'm not going to fit it. Just for a bit of fun. Why?
ATB
OzzyO.
OzzyO
Hello all,
after I get the DROs fitted to the mill I'm thinking about fitting a stepper motor to the mill a) to decrease the low end speed and b) increase the top end speed. But I'm not sure what I'm going to need. This is the plate on the motor now.
This is the sort of motor I'm thinking about fitting.
One other thing it will do is reduce the weight that I have to move when the head is going up, on the head going down that is not a problem .
ATB
OzzyO.
Rob Pulham
Yours looks a little more complicated to fit than mine was. I am feeling a bit under the weather so I will resume posting when I have more head space.
I note that your mill was made in the GDR, which reminded me of something that I read.
While looking for ideas to make my lathe more rigid. It may of course be an urban myth but I read that all the Chinese mini lathes. Which are sold in the west under various brand names, were originally from a design ripped off from someone/company in the GDR.
michael080
I am not sure this is a stepper motor and I am quite sure you don't want to use one. Typically, they wont't run with more than 100-150rpm in the size range above and unfortunately, stepper motors have almost no torque at full speed. The motor above has only two wires, so I guess it will be a simple DC motor. That is preferable anyway, because you can simply apply a dc-voltage to let it run. Stepper motors need a special voltage pattern on their two coils to rotate.
Michael
Wholly agree with Michael, a stepper motor is not designed or intended for driving spindles.
I purchased an AC drive with speed control for my mill. Definite improvement but not quite the success I hoped for.
Martin Shaw
Not a myth at all Rob, all Chinese made mini lathes have their design origins in the Emco Unimat. Emco had the Unimat 4 made in China and inevitably it was copied, initially pretty badly but for a lot less money. The outcome was blatantly obvious, the customer preferred to pay less and accept the lower standards and Emco stopped making hobby machines.
Martin
OzzyO
Hello all,
just for completeness here a couple of extra photos.
The HobbyMat MD 65 lathe
The Hobbymat BEF 65 on it's own
The HobbyMat MD 65 & the milling attachment BEF 65
ATB
OzzyO.
