SimonD’s workbench
Might be time to buy a decoder, but I’m not sure where the speaker is going. Maybe between the cylinders.
Salt?
I went to the Ally Pally show yesterday, there were a couple of captivating layouts on display including a 4mm model of the Wantage tramway.
in what I took to be a gasworks siding was a pitched roof salt wagon. Judging by the vast range of models of this style of wagon in all sorts of colourful liveries, salt was obviously a significant source of trade, I guess originating in Cheshire, and going all around the country. This got me thinking.
Presumably not for the fish & chip shop market. So for what? Preserving fish & making bacon? What else?
back to the bolsters
thirty pages and eight months on, I said something about them "staying this way for months". not wrong!
So a little progress on the bolster wagons. Unfortunately I cannot complete one of them this evening because I broke the coupling guide plate and I don't have a spare :rant:
however, the buffers and couplings work very satisfactorily, even allowing for the very limited space between the Ambis W irons and the buffer plank. There is about a millimetre of travel, and marginally more for the hook.
And the end on which I didn’t break the reinforcement
I’m back on this, amongst other things…
and still have the question as I have failed absolutely in my online search for a photo r drawing of this wagon, so have no idea how to letter it.
Is “OWK/2” actually a diagram number?
all suggestions or info most gratefully received!
Paul Tomlinson
Simon, don't waste any time on "OWK2" - it is as you supposed the JPL catalogue number. ""0" Wagon Kit 2" is my guess...
I have one of those, and, to my shame, I still haven’t finished it. Made some progress, but…
@John Baker will recall the tanks…. Which are 3DP after I made a nonsense of the metal ones in the kit (hint, don’t use elastic bands to hold it all together whilst the epoxy sets, or, at least, if you do, make very sure it doesn’t set with a twist in it…). Anyway, it’s easier to do the rivets in 3DP.
I must get around to doing the steam heating and then finish it off.
And for everyone else doing one of these, CRT do rub-down transfers, and whilst you can’t see it, each tank is labelled “A” on one side and “B” on the other, because I’m a prat.
i suppose I could have worked out the kit catalog number thing, thank you all.
Meanwhile, do we have any idea about appropriate 1930 lettering for the wagon, which I suspect to be of LNWR origins?
atb
On a whim I purchased @MarkR ’s siphon
As he said, it needed a little attention and is already looking rather better. One axle box had been damaged, has now been carved off, and will be replaced when I do a 3DP version
The bogies have had a dose of rattle can black and now boast blue (oil) axle box covers and I now need to obtain some matt varnish to cover the body, which is nicely transferred but appears unpainted.
I’ll then give it a dose of grime and call it a wrap. Here with my Minerva inside framed version.
John Baker
atb
The twin tank is looking great! Good to see it on wheels :) You've been making good use of your printer since I did these for you - you could have a whole fleet of them.
All the best,
All the best,
So long as it's only a small one. Many years ago, I did see a picture that suggested there were at least three. But probably only three.
We have progress on several fronts. The OWK2 wagon appears to LMS ex Caledonian, judging by the axleboxes which are grease type I think - anyway it’s part painted and a bit weathered and when I get around to ordering some transfers I’ll do a bit more.
The bolster wagons that John Duffy kindly sent me have had a coat of grey and likewise are awaiting transfers and weathering - and the big shackles on the bolsters themselves.
The siphon has had a new 3DP axle box fitted, and is awaiting a bit of filth to tone down the rather stark paint on the bogies, and lift the detail a bit
It’s the left one if you can’t tell…
And, on the bench today is the naughty pannier.
Which has crossheads, and better yet, they slide on the slidebars and they don’t catch on the coupling rods.
Not happy with the connecting rods. Not happy with the screw heads on the centre & rear crankpins either. Mmmm.
And these came off the printer last night
A bientot
S
Dug my Guzzi out of hibernation and did some spring maintenance on the old girl yesterday. I then went motorcycling a bit today (spectating at Lydden Classic Bike racing, shame the wind was so bloody cold) but in between times, I have been doing a bit more on the dreaded pannier...
I ran the loco with coupling and con rods, crossheads, etc., fitted, and it's just not quite sweet. And, as I said, I didn't like the use of 12BA screws as crankpins. I was quite pleased with the 3DP crossheads, though I am a little concerned about their long term survival. I guess the answer is to make spares. (or get some cast in metal...). I suspect the etched con-rods that came with it are touching the motion brackets. They shouldn't, but clearances don't scale very well, especially with the variable position of the axle due to the CSB suspension.
The front crankpins have been made - they will keep the 12BA CSK screws to retain the bushes - I have drawn up some crankpins for the driving and trailing axles which I shall perhaps turn up tomorrow evening. These will take a 10BA nut to retain the rods. At some point, I have to summon up courage to machine the conrods (and I have a set of coupling & connecting rods for Tony's Manor that need doing too...)
Still, onwards!
S
In theory there shouldn't be any concerns about the 3DP crossheads as they are not taking any strain nor transmitting forces.
3DP coupling rods on the other hand may give cause for concern as they are transmitting forces to the other wheels.
Thanks Dave,
I just don’t have a feel for their long term survival.
As you say, the loads are negligible, though there is some rubbing, and there is likely to be a little oil around.
I guess @Pencarrow Chris (and I) will find out, in due course!
Coupling rods are Premier!
The conrods, and all the rods for Tony’s Manor will be milled mild steel. I hope.
atb
