Your best bet would probably be copper wire, something like domestic lighting cable which is 1.5mmsq, not sure on dia (can check later at work if required or find what you wish if you have amore specific size), but there will be a cable that will have that dia or pretty much what ever you wish within reason, its more pliable than brass and easier to mark and easier to bend/sag if you wished, look for single core cable, not multi strand.
To mark it you could run it through some rollers, say a ball race on one side and a....don't know the name, its early and I need more coffee
...but the gear that sits on the axle of a worm drive, they have diagonal cut teeth, the alternative is to chemically blacken and then paint a rust/steel colour and then paint the highlight ridges on with a small roller suitably modified to either give raised edges or troughs, IE light painted ridges on a dark back ground or dark troughs on a light back ground.
Rebar is often wrapped in bundles and then covered in a plastic material, you could model that by covering your bundles in heat shrink, it comes in many colours but blue or yellow would look good and stand out well, then you'd only have to worry about the few inches that stick out of the end. If your modelling modern day, say 1990 onward I'd go with the covered stuff, earlier then I'd guess it was shipped raw and exposed to the elements.
The BDA has caught my eye too so I'll follow yours closely, there are many loads you can use and I think I'd have steel I beams, or billets, maybe even flat sheet, so many choices for rusty or clean steel materials to choose from
HTH
