Yes - I was examining the one in my kit earlier, that's exactly what it looks like!
I should have added, more efficiently.The 9Fs. had a good boiler and did not need this to help them produce steam.
OzzyO.
Paul,
The purpose of the Franco-Crosti boiler isn't to improve steaming, it's to improve efficiency by making use of heat that would otherwise disappear up a chimney to provide feed-water heating.
There were two issues with the BR implementation, one was the exhaust gasses becoming too cold which not only reduced efficiency, but also lead to the precipitation of sulphuric acid, so increasing maintenance.
The second, much simpler one is that exhaust injectors are relatively uncommon in European practise and the combination of the already good 9F boiler with exhaust injector had pretty high efficiency to start with.
Yes - I have all the 9F books Paul! I might buy some tube for the pre heater if there is a suitable size at Telford. I think the original intention was to save coal, by trying to make a more efficient boiler as coal prices were going up.
The main boiler has 3 clacks... was there a direct feed?
the boiler will have been washed in running water with an old toothbrush about 5 times during todays work session.
.....both 20s out of action with no motor drive from the decoders. I was chancing my arm with MX645s with twin motors, so decoders with more va va voom are going in.
