Morning David.
Thank you for your kind words. I do try and ensure the overall picture blends.
Yes, the shelves are LACK floating shelves various lengths but all at 26cm width.
The scenic boards all utilise a 120cm x 40cm table top from a LACK ' nest of tables'.
It comes with a second table 55cm x 40cm, another potential baseboard......
All are 5cm deep.
The beauty of these are the lightness and the cost. The main board and two fiddle yards came in at £42 plus another £9 for the MDF for the backscene.
Bleat Wharf was £31 for the baseboards and Sheep Lane used two shelves costing £18 in total.
The draw back is the fact they are solid on the bottom. Wiring can be threaded through holes drilled in the back and I am guessing points could be moved by wire in tube subject to the height of the trackbed.
The bonus of having a solid bottom to the board is that of tidyness and the ease in which a small layout such as these can be set up on, say, a dining table for playing with.......operating.
Interally they are a type of card board 'honeycomb' which provides the lightweight construction.
I have not tampered with this as it is this that provides the structure. Any fitting of point motors underneath would require a hole in the bottom and material removing. In theory if the resulting hole was boxed in, this may retain the rigidity. However I have not tried this so cannot vouch for the effectiveness or otherwise. In any event a route would have to be found for any wiring which could be tricky.
The photos below show Mutton in its infancy and as is now......ish ( April 18)
