richard carr
The Dapol Turbot wagons have finally arrived.
They look gorgeous if you ask me, and for an early 1980's layout like mine you can treat them as being brand new if you want as that was when they were converted from coil carriers.
So for the S7 modeller the big question is, can this convert easily.
The answer sadly is NO !!!!!
Here's the view underneath the model
There is lots of great brake detail and the bogie sides look good but the bogie only measures 49mm over the outside of the frames, when it should be more like 58mm and the edge of the frames should line up with the edge of the body the gray moulding in this picture.
So if you want to convert these to S7 you will need to widen the bogie as there is just not enough room to squeeze an S7 wheel between the bogie frames as they are now.
Another job I didn't really want.
Here's a link to one of Paul Bartletts photos of a real one, you can really see how wide the bogies should be.
BR Turbot Ballast open YCV YCW
