Jim smith-wright
Dapol have recently released a 4mm scale model of the GWR streamlined railcar. The model depicts one of those ordered in January 1935 to lots 1546 and 1547 meaning it can cover railcars number 8 to 16 (number 17 was ordered at the same time but was a parcels version). Overall first impressions are good. Not being all that familiar with the real thing it looks the same as the pictures in 'The History of the Great Western A.E.C. Diesel Railcars' by C.W.Judge. There are a few things that stand out immediately though as room for improvement. The interior isn't great being a 1 piece moulding with a huge lump in the middle to over the underfloor (well below the window line anyway) motor. With something with such big windows this isn't ideal. The bogies look very under nourished.
First steps in converting to P4
The model uses a single driven bogie which has split axles, picking up through the bearings. The other end is a more traditional coach type bogie with wipers on the backs of the wheels. You might be able to use the Branchlines class 108 conversion for the power bogie as it looks a similar arrangement but as I didn't have one I can't say for sure.
I used standard wheels and drilled the center gear out 2mm to fit. I disconnected the wire from one side and used a little bit of copper clad and phosphor bronze wire to arrange new pick ups.
At the 'trailing' end things don't looks so easy. The bogie is very, very narrow. No doubt a compromise to allow any sort of swing on the full skirted versions on 00 curves. You can see from the picture that a standard 26mm axle is wider that the bogie. You might be able to fit P4 wheels on the original axles as they do just about fit between the sideframes but...
... lets face it the super skinny bogies look more than a little bit naff. The quite low relief details really don't help either. No doubt another compromise for the skirted models.
The powered end has plug on sideframes, like a Heljan diesel so these can be easily spaced out to something approaching the real thing. The difference is quite marked to my eye for as good as no effort.
This is the driven side after its been re-spaced - the additional drive details go some way to mask the low relief nature of the basic sideframe.
I await a Brassmasters 7 ft bogie to redo the trailing end with new pickups which should kill both of the problematic birds with the same piece of small aggregate!
