Leaving the bogies to one side for a minute, not sure why - I just can't summon up the motivation to tackle them right now, I've gone back to the main wagons and started adding various details both on the chassis and the bodies.
First up is the top steps on the side of each wagon. On the real things, they're rectangular strip, formed into a square and welded, with a mesh tacked on top. I didn't fancy that approach in 7mm scale much, so I've cheated and cut them out of plastic sheet and then stuck fine mesh on top with Plastic Magic.
The theory is, once painted and weathered, they should look the part, even if you can't see the ground through them!
In roughly the same area, I've also added the brake changeover valves on both side, these again are cut from plastic sheet. For the detail parts, I tend to draw the parts in Corel Draw, print them onto A4 paper and then use Pritt Stick to stick that on the plastic, to give the cutting outline. I find I can generate a thinner line that way and it stops me cocking up the marking out.
The levers are little bits of microstrip cut to length. The rails that the hoods run along have also been added in the pic above, just Evergreen 1.5mm channel.
I much prefer working with plastic to brass for these small details, it's so much easier to shape and form, and stick together. Plastic Magic does a great job of sticking the styrene to the resin as well, which is a great help. It doesn't stick the resin to the resin though, so go figure!
Again, in the similar area, the other bit I wasn't happy about was the etched handbrake wheels included in the kit. You can just about get away with those in 4mm scale, but it's not going to cut in 7mm scale. Giving it a bit of thought, I hit upon the idea of using the kit etched centre with an outer rim of wire.
The rings were formed by wrapping copper wire around the top of the glue in the foreground - a couple of turns for each, like a small spring, which were then trimmed to length. The rim was then cut away from the etches, leaving the centre. The glue was the only thing I could find to hand that was the right diameter, various pens and pencils were tried before and deemed too small.
A quick dab of solder later and they're looking the part! The prototype wheels have the 3 spokes made of rod, but again I didn't fancy that much, so this is an acceptable compromise in my mind.
The next forming job that required some thought is the hoops that sit around the hood stops at the end of the wagon. They're quite a noticeable feature of the design (to me at least) so needed to be included.
Eventually I hit on the idea of forming these in a similar way to the handbrake wheels, although in this case plastic strip was used as I've got a selection to hand. The 3rd size I tried turned out to be the right size (2mm x 4mm).
When these are cut and twisted slightly to square them up, this is what you end up with:
The one on the right has been trimmed to fit around the stop, the others were subsequently trimmed to the same size, and secured to both the stop and the side of the wagon with superglue.
The end result. They are possibly a touch wide, but close enough for me. The bracket sticking out at the end is for the handrail to mount into, and as it's going to be prone to knocking off, I've made that from a bit of brass angle with a 0.45mm wire soldered in, which is then secured to the body with superglue.
I'm very much in the 'adding more detail while frantically trying not to knock off what's already been added' part of the project now. There's not a huge amount left to do on the bodies though, the door gear being the biggest task outstanding before buffers and couplings, although I may add both of those after painting.
Then I'll have to get on with the bogies...
