7mm Steve Beattie 3D-Printed Class 22
smgee
Greetings fellow Thunderers. I thought I'd start a build thread on a new Steve Beattie Class 22 kit. I'm sure I'll be calling on the WT big brain from time to time...
The kit is predominantly 3D-printed resin, with chassis components in more sturdy FDM. It wasn't hugely expensive at under £190, but not as refined as the JLTRT/MM1 offering, so I'm intrigued to see what can be made from it. This will definitely NOT be a cost-no-object build!
I decided to build a running chassis first. The frame comes in 2 sections, with some locating/reinforcing brass dowels (thick wire) at the joint faces. The faces needed a small amount of tidying, and the holes for the brass dowels needed deepening slightly. The two halves were glued together on a flat surface, up against a straight edge, using some VMS flexible black CA, which is great for seeing how much you've got on your fingers!
Next job, fit the bearings to the bogie frames. This is where I hit my first problem...
The bearings are standard 0.25" / 6.35mm OD, but the holes in the bogie frames are 7mm. I wondered about just glueing them in with the wheels fitted, sat on a flat surface, but they were all over the place and wouldn't stay put.
I found some 7mm OD plastic tube to sleeve down the bearing holes. This was glued in place, the ID opened up fractionally to fit the bearings, and the whole thing checked on a flat surface. Spot on.
The bearings were glued in and the excess tube cut away.
In case you're wondering, those slots in the cross pieces are for a Delrin chain. We'll be re-visiting those shortly!
timbowales
Steve, those wheels look like disc ones. I was under the impression that Class 22 DH had spoked wheels?
edit: Just checked in BR Main Line Diesels and, yes, spoked wheels!
  • Like
Reactions: AJC
smgee
Next job, gearbox, motor and Delrin...
In an attempt to keep a lid on costs, I decided to power a single bogie. It shouldn't be a heavy model and won't be pulling huge loads. The Roxey Mouldings 13:1 gearbox is very reasonably priced and I found what I think is the 1833 sold by Taff Vale, but from an alternative source - so under £30 for both.
I've never built an etched gearbox before, but managed to put it together without making too much mess. It seems to be a nice, compact unit, but the worm wheel would not fit on the axle. It's hard to measure the bore accurately with callipers, but it's definitely undersize. Hmm, there seems to be a bit of a theme developing here! Those bearings are just for show and not fixed in yet.
The next problem revealed itself when I took some measurements. The gearbox frame is approx 12.6mm wide, the Delrin sprocket, 7.9mm wide. My calculator says that's 20.5mm. The space within the bogie frame? 19.8mm. Arse.
Of course, I'm conveniently ignoring the bearings, which only make matters worse. The flanges of the gearbox bearings are each 1mm thick, and the bearings in the bogie intrude inside of the frames slightly. They can be filed flush, and I figure I'll have to narrow the Delrin sprocket by 0.8mm or so, but I'm not sure what to do with the gearbox.
With the bearings arranged like this (contrary to the instructions), the worm wheel is spaced to roughly the right place:
So what about turning up some new bearings like this, that are both flush with the frame and space the worm wheel correctly (exact measurements TBD)? I'd welcome the thoughts of the WT Big Brain here!
Osgood
Or you could swap the bearings over to the opposite side so that the flange is on the inside, spaced from the frame by washers to get a snug clearance fit with the gear, then solder the lot up and simply file off the part that protrudes flush with the outside of the frame sides?
Overseer
Being lazy, I would just use the gearbox bearings as intended with the larger diameters adjacent to the worm wheel plus space for thin washers, then solder the bearings in place and file off anything protruding on the outside of the gearbox. Achieves the same result as custom turned bearings with no effort.
Narrowing the delrin sprocket should not be a problem. I don't like stressed delrin (can result in splitting) so would make sure it is a sliding fit on the axle and drill and pin with a small piece of wire through the axle.
spikey faz
Steve
That glue looks ideal for glueing on those little fiddly items like lamp brackets, with less fear of them pinging off compared to normal superglue. I've just watched a video of the above product being used and I think I'll have to get some. It seems to be less 'brittle' if that makes sense.
smgee
Steve
Absolutely, Mike. It's not noticeably bendy when set, but I think it's intended to give a little, whereas regular CA is quite brittle. This video nicely illustrates it:
VMS alone does a bewildering range of flavours, with thin, and slow-setting, and resin/3D-specific variations:
Cements-picker | VMS VANTAGE MODELLING SOLUTIONS
Not cheap, but definitely worth it.
VMS – Scale Model Shop
Keep the nozzle clean and store the bottle in the fridge and it'll last for ages.
smgee
No significant progress to report on, but it occurred to me that I haven't posted much info about this kit.
The body is printed in 5 sections which, like the chassis, use brass pegs to (hopefully) aid alignment.
Throughout the kit I've found a few distortions, as if the resin hadn't cured fully, or needed better supports. Nothing major and no doubt fixable, but it's a shame.
The bogies have some lovely details, but again the odd distortion here and there.
Being gullible/optimistic, I actually have 2 of these kits! I'm building the first one for a friend (D6319), so I'll make all the mistakes on his and then I'll build mine (D6339)! ;)
The 2 kits have different noses (D6319 on the left):
...and Timken (D6319) or SKF (D6339) axleboxes:
The rest of the kit is a collection of not terribly interesting bits, mainly resin, but a few FDM:
@Len Jones is also building one of these kits and has had some trouble with the side grilles, so they'll need to be removed from their supports with great care.
I still need to resolve the gearbox problem, but I threw everything together to look for any potential motor clearance issues. There seems to be plenty of space:
The one bit of progress I have made (bearing in mind the problem of insufficient space within the bogie inners - see post 4) was to build another bogie, sleeve down the bearing holes again, but space the bearings outboard with some washers so that they don't protrude inside the bogies. This will save having to file them flush and remove any burrs. With wheels fitted, the bogie sat perfectly flat again, so I think the FDM prints, while not looking like much, must be quite accurate.
paulc
But you still have enough room for the correct back to back Steve ?
Just checking .
You don’t want any sideways movement beyond a running clearance on a 4 W chassis, it doesn’t help at all, and makes buffer locking more likely, probably more so on a bogie vehicle. Particularly so on 0F, which has significant wheel-track sideplay built into the standard.
Jordan or Plymouth Mad
Mid-Western Thunderer
Seems a bit '2 step forward, 1 back', this kit. On the S.B. brass version I built some years ago the grilles were brass too & actually very good.
At least the cab fronts capture the 'face' better. I did a fair bit of work on the old kit but eventually wasn't happy with the cab fronts & sold it on.
smgee
Thanks Simon, useful to know. This is the first O gauge loco I've built, in fact it's the first loco I've built since a OO K's 517 when I was about 13, so I've no relevant experience to call on! I can add shims outside the bearings if 0.5mm side play is too much, though I think side play will actually be dictated by the gearbox and Delrin cog.
I agree Jordan, obviously done to keep costs down. The kit does include a sheet of small etched brass grilles and, somewhat randomly, handwheels for the cab where a resin print would arguably be better!
